18
I'm using a couple arduino pro mini's (3.3V) for a home automation project and want to add relays to the final PCB design to switch some stuff on and off.
Since I want to use a 5V relay like this: HF 46F 5V, Miniature HF power relay, 5 V, 1 NO 5 A
I wonder how I can switch this relay with the arduino, since the pro mini only has an output of 3.3V on the pins? The arduino is driven by a 3.7V Li-Ion Battery.
Another question would be how to use the relay safely with high voltages? (apart from trace-width and trace spacing between high and low voltage parts on the pcb) Thanks in advance!
    \$\begingroup\$ Why not pick a lower voltage relay? There is a 3V version of the model you linked to. You may find that 3.7V is enough to close the contacts on some higher voltage relays; it will say in the datasheet. The minimum 'pick-up' voltage for the linked relay is 3.75V, so it would not work. I have no experience of undervolting a relay long term, so I cannot say for definite that you should rely on that technique. \$\endgroup\$ Jan 23, 2016 at 18:41
  • \$\begingroup\$ Run the relay from the higher voltage PSU that's feeding the Arduino and take the load off the 3.3 V regulator. You're looking for a MOSFET or transistor switch. There are thousands of posts on this SE site regarding this. \$\endgroup\$
    – Transistor
    Jan 23, 2016 at 18:43
    \$\begingroup\$ @CharlieHanson there is no way the controller can source/sink enough current to directly drive a relay like this, even if the coil voltage matches. You'll always need some sort of a buffer stage. \$\endgroup\$
    – jippie
    Jan 23, 2016 at 18:45
  • \$\begingroup\$ @jippie I did not say the controller ever could. As this was a comment and not an answer I didn't see the need to wax lyrical about current issues. \$\endgroup\$ Jan 23, 2016 at 18:54
  • \$\begingroup\$ Why is this battery powered and not using a power supply derived from the load supply? Even if you want the MCU battery powered for backup purposes, run your switching element (relay, etc) from a supply derived from the load supply - there's not a lot of benefit to clicking the relay if there's no mains power to run the load, and your battery life will be a lot better if you don't run the relay coil off of it. \$\endgroup\$ Jan 23, 2016 at 20:07
14
The problem is not only related to voltage; but also to current. Basically; the coil operates on a set voltage and requires a set amount of current to be switch on. Commonly, this current to switch on the relay surpasses the maximum power for an output pin.
There are a few ways to control a relay from an Arduino:
  1. You may want to use an Solid State Relay instead, these often can be controlled from 3V to 32V with very low current. Due to the solid state nature of these relays they're also commonly faster, optically isolated, use less power and likely less prone to mechanical failure. You theoretically could dim your lights using one of these relays by turning it on/off fast (PWM signal). But there are better ways to dim lights.
  2. You may want to use an 'Arduino Relay Board' these boards are specifically designed to be ran off an output pin. Do note that some boards are built for 5V and some even require an external 12V input.
  3. You can design a circuit using an MOSFET (and fly back diode) to power the relay directly from the battery and use the output pin of the Arduino for the control signal. (See the other answers) This may not work if the relay requires more power than your battery can provide, in this case you may need an step-up converter to convert your 3,x volt to 12 volt.
  4. You may use other interfacing methods for the relay, for example you could use an IR controlled relay and send IR signals from the Arduino. In this way, power to run the relay is not consumed from your battery. The options are limitless, but you could use RS-232 or even WiFi; though; however those would require an intermediate component to do the translation.
In short; especially since it's an battery powered device; I would suggest using a solid state relay, since these typically require less power.
It's also worth to note that activating the coil of the relay usually continuously draws power (unless if you have a latched relay). So it may be worth to use the relay 'inverted'; to turn something off rather than on; if it's a device that is usually on or to use a latched relay.
Control other devices from an Arduino:
For devices that do not draw a noteworthy amount of current, you may use an 'Logic level converter', typically to interface an 5V Arduino with an 3.3V Arduino.
In some cases it may even work without the logic level converter, but there's no guarantees that it will continue to work if; for example your battery is going low.
Safety:
Your question also included a note about safety, this is actually an entirely different question and too long to fully cover here.
But be sure to use a proper enclosure and it's recommended to optically (and physically, by separating traces) isolate mains voltage from the Arduino. To avoid that failure of a component could lead to your USB becoming mains voltage (110-230VAC).
  • \$\begingroup\$ @jippie You're right, immediately edited it when I saw it. \$\endgroup\$
    – aaa
    Jan 23, 2016 at 18:52
  • \$\begingroup\$ thanks! I think it would be better to use a 3V relay, in this case I don't need the voltage regulator (which takes much space which I don't have).<br/> I will go with the cheap chinese Songle SRD-03VDC-SL-C (i will only use this for voltages under 20V DC) To drive the Songle relay safely, I need a transistor and a diode (please correct me if I'm wrong) I will go with the NPN 2N2222 and the 1N4007 if that's ok. Here's how my schematics are looking (D5 is Digital arduino pin 5; GND.2 is GND of the arduino): link \$\endgroup\$
    – Blacky
    Jan 25, 2016 at 2:05
  • \$\begingroup\$ @Henry I don't know that much of Electronics/schematics, but that's not going to work. You need to put the battery in series with coil, and use the transistor as a "switch". So the Arduino can activate the transistor, and let the higher current of the battery to the heavy lifting. I could check if I can make a schematic, but it'll be tomorrow. \$\endgroup\$
    – aaa
    Jan 25, 2016 at 2:09
  • \$\begingroup\$ yes i realized i mixed something up there :D i googled a bit and ended up with this new wiring: link Is it correct? thanks in advance! \$\endgroup\$
    – Blacky
    Jan 25, 2016 at 2:29
  • \$\begingroup\$ @Henry, I was thinking of something like this wired.com/geekdad/wp-content/uploads/2012/09/relay_driver.jpg just google: "transistor drive relay circuit" you're not the first person to do this, so no need to reinvent the wheel (in this case) :) \$\endgroup\$
    – aaa
    Jan 25, 2016 at 2:41
This circuit can solve you problem. I hope it works for 3.3 V supply and 5V relay as well. To explain the reason it works, quote from the linked page:
"This circuit allows a 12v relay to operate on a 6v or 9v supply. Most 12v relays need about 12v to "pull-in" but will "hold" on about 6v. The 220u charges via the 2k2 and bottom diode. When an input above 1.5v is applied to the input of the circuit, both transistors are turned ON and the 5v across the electrolytic causes the negative end of the electro to go below the 0v rail by about 4.5v and this puts about 10v across the relay. "
  • \$\begingroup\$ Where does the 5V come from? \$\endgroup\$ Jan 23, 2016 at 18:56
  • \$\begingroup\$ I missed the point that no other supply was available. Updated the circuit. Thanks for bringing it to my notice. \$\endgroup\$
    – Abu Bakar
    Jan 23, 2016 at 19:17
Find a relay that has coil for 3.3volts, or . . .
You are going to need to obtain (or create) a 5 volt supply.
If you search for "step up breakout" you will find products that can step up 3.3v to 5 volts. A device like this will cost a few dollars.
Or, If you are driving AC circuits, you could use a TRIAC driver circuit directly from your 3.3 volts.
An SSR (solid state relay) could also be considered.
EDIT : based upon comments, I just realized you will need a transistor (MOSFET) to drive the coil of the relay.
  • \$\begingroup\$ Your edit invalidates the whole rest of the answer. Once you have the transistor (actually, better bipolar than FET) the MCU voltage mattes little at least in the 3.3v and up range. \$\endgroup\$ Oct 12, 2016 at 22:59
