I made a design using PIC32mx and everything is working well. I was trying to debug my first program and for this case instead choosing PGEC1 and PGED1 I am using PGED2 and PGEC2. Problably that's the reason why I am getting the following message while debugging:
The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings.
This is the schematic I have done:
PGC/PGD schematic
Where can I modify the configuration bits to enable the debug mode?
    \$\begingroup\$ The #pragma config sentence can be used to reassign PGC,PGD. The device-specific header contains all possible values, open it and search for 'config'. \$\endgroup\$ Jan 23, 2016 at 20:28
The sentence to enable the debug mode for my case is:
#pragma config   ICESEL = ICS_PGx2
