I'm trying to make my Nvidia board (TK1) to boot automatically. i.e., when the power goes off and comes back again i want the board to power up automatically. I have tried the Nvidia forum and found a way to do it, but it works only when i manually pull the charger pin from the jack in the board and re-insert it. When the AC power is turned off (without pulling the plug from the board) and turned on again the board doesn't boot up automatically.
I want to know if it is possible to make a automatic switch circuit that would do the job of push button(which will replace the ON switch)
Note: I was also suggested to use a relay to make the button work, coz of it's bulkiness i cannot use it.
  • \$\begingroup\$ Reed relays can be very small and would do the job for a power button without having to worry about what circuitry is connected to the button. Here's one that's less than an inch long: digikey.com/product-detail/en/HE721C0500/HE112-ND/133219 \$\endgroup\$ – DoxyLover Jan 25 '16 at 6:05
  • \$\begingroup\$ @DoxyLover the rely would wok fine which can be used in the next design, for debugging purpose i would like to construct a circuit and test it. - Thanks \$\endgroup\$ – TSDCR Jan 25 '16 at 6:12
  • \$\begingroup\$ Probably shorting the POWER switch would work \$\endgroup\$ – m.Alin Jan 25 '16 at 9:26
  • \$\begingroup\$ @m.Alin it would work if the power switch is a normal switch.but it is a push/release switch which makes a small pulse to make the line go low and then high again. so shorting will not do any good (tried already). \$\endgroup\$ – TSDCR Jan 25 '16 at 9:43
I have finally found the Answer to do this - use a comparator IC (typically a IC that would generate a reset if the input goes below a certain level). Found one in TI(TPS3700) - just the right one.
