In a function generator, when I set Zout to be 50 Ohm, and Vpp is 1V. Is this Vsource, or the Vload when I have a matching load of 50 Ohm?
  • \$\begingroup\$ On almost every function generator that will be the Vload voltage when you load it with 50 ohms. So not 100 ohms as in your schematic ! \$\endgroup\$ Jan 25, 2016 at 18:47
Typically, when you set the 50R output impedance on a signal generator, it assumes that the load is also 50R. Therefore, you will get 1 Vpp with a 50R load and 2 Vpp open-circuit.
Some function generators allow you to specify the load impedance, so the SG knows to calculate the correct voltage.
From Agilent 33220A Manual:
