I have a watt meter connected to the primary of one transformer to measure power. The output of this transformer is connected to the input of another transformer.
The watt meter is measuring the inductive load of the primary of the second transformer, as 'real power'. I figured I have to add a capacitor in parallel to the primary of the second transformer to filter out the current at the given frequency but I am not sure.
If I connect a load to the secondary of the second transformer, the reactance of the primary of the second transformer will change, in turn changing it's ability to filter out the frequency with the parallel capacitor.
Is what I am describing true? Or does it work differently? How are power lines avoiding experiencing 'real power' dissipation from transformers of appliances in our homes. I know transformers are inductive and give power back to the source. But in the double transformer test I describe the watt meter was measuring the 'apparent power' of the primary of the second transformer, as the the 'real power' in the 'eyes' of the primary of the first transformer. so if I measured voltage and current at the primary of the second transformer, I would multiply them to get an apparent power of 20VA. The watt meter would show 20Watts (real power) at the primary of the first transformer.
I hope that is clear. Thank you.
