I made some simple calculations regarding block diagram algebra. The problem is that I don't get the same result using matlab.
Here is the system with it's corresponding blocks:
$$H_1 = z+2$$ $$H_2 = \frac{1}{z^2+2z+1}$$ $$H_3 = \frac{z}{z+2}$$
This simplifies to the following according to the block diagram rules:
$$H = \frac{H_1*H_2}{1-H_1*H_2*H_3}$$
After some simple math I get:
$$H = \frac{\frac{z+2}{z^2+2z+1}}{1 - \frac{z+2}{z^2+2z+1}*\frac{z}{z+2}} = \frac{\frac{z+2}{z^2+2z+1}}{\frac{z^2+2z+1-z}{z^2+2z+1}} = \frac{z+2}{z^2+z+1}$$
Now if I try to get the same result using matlab it results in a system of order 5 and a system of order 3 after reducing it using matlab's minreal command:
% initialization
z = tf('z',0.1);
H1 = z+2;
H2 = 1/(z^2+2*z+1);
H3 = z/(z+2);
H_ = (H1*H2)/(1-H1*H2*H3)
H_ =
      z^4 + 6 z^3 + 13 z^2 + 12 z + 4
  z^5 + 5 z^4 + 10 z^3 + 11 z^2 + 7 z + 2
Sample time: 0.1 seconds
Discrete-time transfer function.
H_ = minreal(H_)
H_ =
      z^2 + 4 z + 4
  z^3 + 3 z^2 + 3 z + 2
Only using Matlab's built in feedback command yields the correct result after evaluating minreal:
% calculate system transfer function using matlab's feedback command
H = feedback(H1*H2,-H3)
H =
      z^2 + 4 z + 4
H = minreal(H)
H =
     z + 2
  z^2 + z + 1
Could you please guide me what I am doing wrong using the straight forward calculations for H_. Why do I get a system of order 3 after using minreal and not the same result as done by hand (or using feedback command)?
num = minreal(simplify(H1*H2))
den = minreal(simplify(1-H1*H2*H3))
H_nd = simplify(minreal(minreal(num/den)))
num =
      z + 2
  z^2 + 2 z + 1
den =
   z^2 + z + 1
  z^2 + 2 z + 1
H_nd =
      z^3 + 4 z^2 + 5 z + 2
  z^4 + 3 z^3 + 4 z^2 + 3 z + 1
  • \$\begingroup\$ (Z+2) has disappeared from the 2nd term of your analysis. Looks like you got the wrong factors for the 2nd order. \$\endgroup\$
    – Chu
    Commented Jan 27, 2016 at 17:23
  • \$\begingroup\$ Also, there are (z+2) factors that cancel in the 1st Matlab program. \$\endgroup\$
    – Chu
    Commented Jan 27, 2016 at 17:28
  • \$\begingroup\$ Sorry there was a mistake in my hand calculations. Now it is fixed and the same according to feedback command \$\endgroup\$
    – fjp
    Commented Jan 27, 2016 at 17:41
  • \$\begingroup\$ I still don't understand why H_ doesn't yield the same result \$\endgroup\$
    – fjp
    Commented Jan 27, 2016 at 17:42
  • \$\begingroup\$ It is the same - there are (z+2) factors in numerator and denominator that cancel. Perhaps you need to execute minreal a second time. \$\endgroup\$
    – Chu
    Commented Jan 27, 2016 at 17:48
You need to add the tolerance to your minreal function.
This is taken from mathworks website:
"minreal(sys,tol) specifies the tolerance used for state elimination or pole-zero cancellation. The default value is tol = sqrt(eps) and increasing this tolerance forces additional cancellations"
