I'm reading two analog input values (light sensors, with pull-down resistors) on an Arduino MEGA 2560.
One pin is supposed to report the value of 0, while another pin is supposed to report a value of ~800. I know this for sure, because if my sketch reads ONLY 1 of these pins, that's the results I get.
If I try to read both values in a loop, then the first pin seems to be influenced by the second pin in it's reading, and is higher than 0. I know it's good practice to either call the analogRead() command twice or to put a tiny delay between switching analog-input-pin-reads to give the ADC a chance to stabilize. But, even if I call analogRead() twice AND give it a delay-value of 1 sec (!!) the first pin still gives me higher reading than it should.
loop only reading pin 1:
pin 1 = 0loop reading pin 1+2, no delay between calls:
pin 1 = 20, pin 2 = ~800loop reading pin 1+2, calling analogRead twice:
pin 1 = 6, pin 2 = ~800loop reading pin 1+2, with delay(1000):
Trying to understand what's going on ...
Here's the simplest code to test this
int sensor[2];
void setup() {
Serial.begin(9600);
void loop() {
for (int i = 0; i < 2; i++) {
analogRead(i); // read pin twice and ignore first result
sensor[i] = analogRead(i);
delay(1000); // give long delay to let ADC stabilize
Serial.println(sensor[0]);
Serial.println(sensor[1]);
Here's a simplified schematic showing how 1 sensor (TEMT6000 photo transistor) is connected to the analog pin. It has a pull-down resistor to avoid random floating values in case no sensor is connected. The pull-down resistor is so high (220K) to allow for low-light readings. Sensor cables run in parallel with cables feeding an LED. I've included it, just in case. But, note, in all tests listed above, the LED was not turned on.
Now multiply that setup by 8. As I have 8 sensor units connected to 8 analog pins.
