I'm not sure how the addition of the intrinsic region affects the built in potential of the diode. I also can't seem to find any information about it online. Thanks for the help.
How does the built in potential of a pin diode compare to a pn diode?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI'm not sure how the addition of the intrinsic region affects the built in potential of the diode. I also can't seem to find any information about it online. Thanks for the help.
The PIN diode will have the same barrier for the material; however, it will have a different frequency behavior. The N and the P regions are highly doped, take a standard band diagram and then stretch it out. The barrier height will be the the same.
I have used these devices as attenuators, and the low frequency behavior is identical, but at high frequency, they look much like a resistor.
I believe that there is a write up on them Andy Grove's "Physics and Technology of Semiconductor Devices"; however, I have not seen them described in detail anywhere else.
