I drive sht11 temperature-humidity sensor from mcu, the reference design from MikroElektronika uses the following: To make sda pin high, the pin connected to sda (which is pull-up) is not given to logic 1 instead, it is made input to make sda high.
I used this and it worked, I ask is it better and why?
* Generates a transmission start
*       _____         ________
* DATA:      |_______|
*           ___     ___
* SCK : ___|   |___|   |______
void Transmission_Start() {
  SDA_Direction = 1;                     // define SDA as input
  SCL = 1;                               // SCL high
  Delay_1us();                           // 1us delay
  SDA_Direction = 0;                     // define SDA as output
  SDA = 0;                               // SDA low
  SCL = 0;                               // SCL low
  SCL = 0;                               // SCL low
  • 4
    \$\begingroup\$ On page 5 of the datasheet it says "To avoid signal contention the microcontroller must only drive DATA low. An external pull-up resistor (e.g. 10kΩ) is required to pull the signal high" - I guess it means that you don't want to have the possibility that your micro drives it high while the sensor drives it low, giving a direct short. \$\endgroup\$ – Roger Rowland Jan 30 '16 at 9:24
    \$\begingroup\$ @RogerRowland suggest you make this an answer so the question does not remain unanswered. \$\endgroup\$ – DoxyLover Jan 30 '16 at 19:18
