It is accepted practice to maintain lead acid batteries at a float voltage of roughly 2.3 Volts per cell. The precise value depends on battery type and battery chemistry and ambient temperature. We have all done this for decades. Some charger manufacturers use a pulse scheme where they have a comparitor with hysteresis that turns the current off at say 2.3V and on at say 2.2V per cell. This is done at relatively small currents like C/100. I can see that this should represent a energy saving and I know that it is easy to implement by hardware or software. The question is: What is best for the life of the battery?
    \$\begingroup\$ Pipe ..Most power supplies take a idle current ,Example chinese artesyn 1500W pulls 22W to do nothing .If the circuit can spend most of its life shut down there will be an energy saving or average power saving . \$\endgroup\$
    – Autistic
    Jan 30, 2016 at 9:38
    \$\begingroup\$ The battery is alone but the SMPS say non china has 90% full load efficiency that is say 80% at 5% load but at 1% load it is 30% efficient .In a nutshell you set up the current where charger efficiency is reasonable .I will charge my leaf and smoke my pipe. \$\endgroup\$
    – Autistic
    Jan 30, 2016 at 9:51
    \$\begingroup\$ @pipe You can run the charger for ten minutes at 1A (plus 0.5A idle power) or for five minutes at 2A (plus 0.5A idle power) then turn it off entirely for five. Which uses less power in total? (All numbers entirely made up in this comment) \$\endgroup\$
    – user253751
    Jan 30, 2016 at 12:18
    \$\begingroup\$ @pipe It demonstrates the principle the OP is trying to tell you, which is that the charger uses some power when turned on, regardless of the charge rate. So by turning it off except for short bursts you save energy. By "made up" I merely mean that I didn't get those numbers from any actual charger or battery. \$\endgroup\$
    – user253751
    Jan 30, 2016 at 22:27
    \$\begingroup\$ if you want the battery to last you need a periodic equalizing charge in addition to the float charge. \$\endgroup\$ Feb 7, 2016 at 5:25
From Wikipedia's Lead-Acid Battery page, here are two quotes:
"Starting batteries kept on a continuous float charge will suffer corrosion of the electrodes which will also result in premature failure. Starting batteries should therefore be kept open circuit but charged regularly (at least once every two weeks) to prevent sulfation."
and
"There are commercial products claiming to achieve desulfation through various techniques (such as pulse charging), but there are no peer-reviewed publications verifying their claims. Sulfation prevention remains the best course of action, by periodically fully charging the lead-acid batteries."
So, the answer to your question, "What is best for the life of the battery?" it seems, has a surprise answer -- Don't Float Charge -- because it reduces battery life. And there is corrosion on the deep-cycle batteries too, it just doesn't affect them as much because their plates are thicker.
You could implement a "Smart Float Charge" feature that will allow the customer to still just keep your charger plugged in, turned on, and battery attached, for their convenience and peace of mind; but your charger wouldn't actually float charge, instead it would turn the charge completely off and wait the two weeks (as suggested in block quote #1 above), and then initiate a full charge. This will keep the battery ready for use whenever it is needed, which is the main purpose of the float charge, but it will cause much less corrosion, causing the battery of the customer to last much longer. A button to manually bring up the charge a few hours just before use might be nice. Also, don't forget to adjust your charge voltages for temperature -- Arizona charging is probably different from Alaska charging.
Also, during the main charge, you may want to pulse, because it supposedly knocks off the sulfation, also increasing battery life. Do google searches for this, because there's research (I saw it in passing, in searches to try to answer your question, but didn't read it -- just know it's there, and probably very helpful). You may need to pulse in a very specific way during your main charge to knock the sulfation off most effectively.
Since your answers are really in the realm of chemistry, if you want more information, I suggest that you ask further questions on the Chemistry stack exchange. They should be able to confirm or clarify what Wikipedia said (sometimes Wikipedia needs confirmation), more able to point you in the right direction, or answer your original question (which I am going to bet is "if you're going to float charge anyway, it's a low power charge and does not matter whether it is pulsed or constant".)
Hope this helps.
  • \$\begingroup\$ .Interesting Answer .+1 .So you say it is good to pulse and bad to float. \$\endgroup\$
    – Autistic
    Oct 15, 2018 at 21:51
charge chart
Flooded lead acid batteries are full at 12.7V and empty at 11.5V. Charging at more than 0.5V over the full charge "on the charger" is unnecessary and damages them. Each cell is about 2.1V and charging at 2.25V and watching the battery itself does not go over 2.1v is the way to go. Multiply by 6 for a 12V battery.
So, 13.2V to 13.8V on charger and be sure the battery does not rise above 12.7 V. Keep the batteries topped off and never discharge below 11.5V will keep them pretty good. I think a constant voltage is the way to go and as the battery fills it will naturally reduce current as above . I don't see pulsing it will help anything or save any power unless maybe you are in a float charge state ie ,holding it at 2.25V
    \$\begingroup\$ As I understand it, the OP is specificially asking about the regulation in the float phase and effects on battery life. While you give good advice in general, I think you do not answer what was asked. \$\endgroup\$
    – Andreas
    Feb 26, 2017 at 22:06
  • \$\begingroup\$ "I don't see pulsing it will help anything or save any power unless maybe you are in a float charge state ie ,holding it at 2.25V" The chart is pertinent to establish where the true float stage is. \$\endgroup\$
    – April
    Feb 26, 2017 at 22:11
  • \$\begingroup\$ A PID control would be able to use a nearly constant current in float phase. Would that prolong battery life? \$\endgroup\$
    – Andreas
    Feb 26, 2017 at 22:20
-7
Lead Acid batteries simply dissolve the lead and release a voltage. Charging a lead acid battery will stop the lead-acid re-action. Charging a lead acid battery will not cause the lead to Re-Bond to the surface of the lead element. Many years ago Sears paid an engineer to build a lead acid battery that would fail at 32 months use, this was accomplished by calculating a build up of lead at the bottom of the case and shorting the remaining field. Therein Sears would refund a 4 month credit on returns and yield themselves a continued profit on the 300% mark up. Today lead acid batteries are based upon this paradigm, using individual cells that can shortout. One could extend a lead acid battery life by placing a constant positive charge to supply electron bleed-off to the surrounding environment. By placing the battery in a non-conductive environment the positive charge will not be drained as easily. A simple solar cell source of 14-15 volts and as little as 1 watt will maintain the battery in storage. While a larger wattage is required to charge the battery after or during use. A good lead acid battery has an ambient voltage of 12.3 volts or more. When starting your vehicle the battery should not load below 10.3 volts; if below this you have a problem with size or age of the battery, or the starter motor. Replace auto batteries every 32 months, they can last longer depending on usage, but keep in mind that today's expensive computer components do not like drops below the 2.3-2.7 threshold of component designs that can be affected. The charging sinusoidal waveform acting tickler voltage is not nearly as important, except to tighten lead outer valence electrons. This information does not apply to Lithium, Nickel Hydride, Magnesium, Silver Oxide, or others. Each other type have unique concerns also. But more over each other utilizes memory characteristics due covalent or valence potentials. Over charging or over tasking these others can induce extreme heat and unstable elements.
  • 4
    \$\begingroup\$ I'm not sure your answer makes sense and it does not seem to be very well based on the actual implications of battery chemistry. It is also rather poorly formatted. \$\endgroup\$ Jul 18, 2016 at 16:38
  • \$\begingroup\$ I count 18 statements. 15 are wrong. \$\endgroup\$
    – AnalogKid
    Apr 5, 2019 at 12:40
