I'm trying to control my 3v motor from my 5v arduino.
For this i use :
  • 5 volt power source from pc for the arduino
  • L9110 H-bridge module
  • 2 AA Battery as power source for the L9110 H-bridge
Here is the setup :image
however if I touch the h-bridge pin with the 5v source from the arduino (red cable on the image), nothing happens....
Any idea ? if I power the motor directly from the battery, the motor works
Maybe the problem is that I have 2 different power source
You need to complete a circuit in order for the current to flow. Creating a common ground between the power sources (connecting the grounds together) should fix the problem.
| improve this answer | |
