I design the attached circuit: 75 MHz Sine wave that connected to R and C in parallel:
In the output, the amplitude of the sine wave is changing according to the C, more capacitance smaller amplitude of the sine wave.
When I tried that in the lab I got 2 results:
  • 1. When I connected the function generator as the source I got the same results - higher C lower amplitude (of the sine wave in the output)
  • 2. When I connected it to oscillator (http://www.farnell.com/datasheets/75480.pdf) I'm getting different results: the output is a sine wave, but if I make C higher the amplitude becomes lower until the sine wave (in the output) is "flipping" (kind of changing phase) and, if I keep raising the C higher, the sine wave in the output starts getting higher.
  • What are the differences between the two? How can I make the oscillator work like the function generator in this case?
    • \$\begingroup\$ Please clarify 'wave generator' and 'signal generator'. Do you mean the same thing both times? And are you referring to a function generator? \$\endgroup\$
      – user207421
      Commented Jan 31, 2016 at 0:14
      \$\begingroup\$ The oscillator you linked has a CMOS square wave output (not sine) and you are heavily overloading the output with that network. If it is doing something strange maybe you should stop abusing it? \$\endgroup\$ Commented Jan 31, 2016 at 0:23
    • \$\begingroup\$ EJP, When I said 'wave generator' or 'signal generator' I meant function generator - I have Rigol. I tried it one time with the function generator as an AC signal in. At the second time with the HCMOS oscillator as an AC signal \$\endgroup\$
      – Itayd100
      Commented Jan 31, 2016 at 9:36
    • \$\begingroup\$ Spehro Pefhany, the output signal is Sine wave - I connected it to the oscilloscope (just this component with 15pF on the output - like they saying in the spec). I want to understand what I'm doing wrong and how can I do it better. Do you have any idea? \$\endgroup\$
      – Itayd100
      Commented Jan 31, 2016 at 9:41
    • \$\begingroup\$ So why not say so? And why not edit your question when its ambiguity is pointed out? \$\endgroup\$
      – user207421
      Commented Jan 31, 2016 at 11:17
    I'm going to assume that you used something like a breadboard to mount your components, and standard breadboard jumpers several inches long. And there lies your problem.
    75 MHz is just too high a frequency to get reliable results on a standard breadboard unless you use great care. The biggest problem is the ground connection of your scope, which needs to be as short as possible, and connected to the circuit as close as possible to the ground pin of your oscillator. Just as an experiment, try looking at your oscillator output on the scope and try moving the probe around (changing the angle of your hand and probe).
    Another way to look at this is to consider that your physical setup is almost certainly not exactly what your schematic indicates. Long wires will have parasitic inductances which become important at 75 MHz.
    Second, especially with the oscillator, is making sure you have properly decoupled it. Use a 0.1 uF ceramic cap connected as close to the power and ground pins as is humanly possible, with the cap leads as short as possible.
    Comparing your oscillator and an external function generator is fraught with possible difficulties. As a start, the FG is probably putting out fairly good sine wave. Your oscillator, on the other hand, is doing its best to put out a square wave - notice the 3 nsec rise and fall times. This will produce large signal components at multiples of 75 MHz. Granted, the large load capacitances you use will tend to filter these harmonics out, but with varying effects.
    And finally (although perhaps I should have listed it as first), as asdex has pointed out, your oscillator is completely unsuited for the circuit you are investigating.
    First, Thanks for the answers. I post another answer to attach the photos. I know that 75MHz is a problem with a breadboard and because of that I soldered it on protoboard. This is the photo of the oscillator on the board: enter image description here
    And this is the output signal (with just 15pF from the output to the GND, @Spehro Pefhany, @asdfex - does it look like "an elephant-shaped"?): enter image description here
    I know that I'm doing something wrong and because of that I post it here. I search a little more and understood that I need to add a buffer. What do you say?
    • \$\begingroup\$ Hi Itayd100, please go to Help Center > Contact and ask for merge user profiles. \$\endgroup\$
      – bummi
      Commented Feb 1, 2016 at 7:55
    • \$\begingroup\$ What model scope are you using, and what probes? \$\endgroup\$ Commented Feb 2, 2016 at 1:08
