So this feels like a silly one but I'm absolutely stuck. I'm trying to balance the power between a 3 phase source and two 3 phase loads in parallel. One is a Wye and the other is a Delta: layout So I figured out that the single phase source current is 5A per branch, so the source complex power is (3*120V*5A) = 1800 W and 0 var.
The problem comes when I try to find the load draw. It's easy enough to find the delta line-to-line voltage and the current going through the phases of the loads: V and I calcs
When I go to sum the powers, though (including line impedance), I get a strange answer that doesn't balance: power calc
Does someone see my obvious mistake?
Thanks!
Never mind, answered my own question. My line impedance power calc should have been 3*I^2*Z.
| improve this answer | |
