I know that the output voltage and current of an ideal transformer depends on the number of wounding of the coils. It means that no matter how many resistors I put in a series in my secondary loop, the current would not change and it depends only on N (Number of turns in coil).
I have been thought that resistors define the current that flow through them and it is hard to look at the current independent of the load.
Could someone explain the physics behind v1/v2=N1/N2 So is it safe to assume that the current in secondary coil acts as an ideal current source because if I know the source current I can get the secondary loop current no matter what the load of the secondary circuit is
  • \$\begingroup\$ The current depends on the load. No load - no current. So your premise is false. \$\endgroup\$
    – Eugene Sh.
    Feb 1, 2016 at 19:34
  • \$\begingroup\$ The current in the secondary loop depends on the current on first loop and N1:N2. I do not see any loads \$\endgroup\$
    – Jack
    Feb 1, 2016 at 19:36
  • \$\begingroup\$ how do you think the current will flow through an open circuit? \$\endgroup\$
    – Eugene Sh.
    Feb 1, 2016 at 19:37
  • \$\begingroup\$ I think you misunderstood me. What I mean is that how come it does not depend on the value of the load. For example how would it differentiate between 10 ohm and 200 k ohms. \$\endgroup\$
    – Jack
    Feb 1, 2016 at 19:40
  • \$\begingroup\$ I am saying it does depend. The current in the secondary coil is v2/R. If you want to know the current in the primary one - apply the relation you've mentioned. \$\endgroup\$
    – Eugene Sh.
    Feb 1, 2016 at 19:42
In a transformer electric energy is converted into magnetic energy and then back to electric energy.
The formula V1 / V2 = N1 / N2 applies to this process without any losses.
Losses can occur due to:
  • Resistance of the transformer wires
  • Saturation of the magnetic core of the transformer
  • Inductance of the transformer (a transformer is also a coupled inductor)
  • frequency of the AC signal fed to the transformer
So the formula V1 / V2 = N1 / N2 does apply but it only applies to an ideal transformer.
Also an ideal transformer does not lose any power nor will it add any. So that means:
P1 = P2 and also V1 * I1 = V2 * I2
If you would connect a current source to one side of the transformer then the relation will still hold however you must make sure that the current on the other side of the transformer can flow so you must apply a load or short it.
This is the opposite of connecting a voltage source at the primary side, you are expected to have a load at the secondary side or leave it open, but you're not allowed to short the V2 side !
  • \$\begingroup\$ So is it safe to assume that the current in secondary coil acts as an ideal current source because if I know the source current I can get the secondary loop current no matter what the load of the secondary circuit is? \$\endgroup\$
    – Jack
    Feb 2, 2016 at 15:00
  • \$\begingroup\$ If you have an ideal current source on the primary side and the transformer is also ideal, then Yes the secondary side will also behave as a current source, this means, no matter what the load is, the current is defined. It follows from the V1/V2 = N1/N2 formula and using a current source on the primary side. \$\endgroup\$ Feb 2, 2016 at 15:04
  • \$\begingroup\$ In the book that I am reading the voltage and current ratios where derived in this way: First the voltage at the secondary loop was obtained by making the second loop an open circuit. (There is a voltage source at the primary side), then in order to get the current the author summed the voltage around the shorted coil of second circuit. \$\endgroup\$
    – Jack
    Feb 2, 2016 at 15:16
  • \$\begingroup\$ "you are expected to have a load at the secondary side or leave it open, but you're not allowed to short the V2 side !" this is what you said but I am looking at a shorted coil without any loads in the second circuit \$\endgroup\$
    – Jack
    Feb 2, 2016 at 15:17
  • \$\begingroup\$ book is nilsson riddle Electric circuits \$\endgroup\$
    – Jack
