I have a reverse biased photodiode as shown below.
where R1 = 100kΩ. The output is quite low around 50mV. I would like to replace R1 with 1MΩ to get 10x the output. My concern is, if it will have any disadvantage? Does it have any effect on the rise time?
  • \$\begingroup\$ It'll affect the fall time. \$\endgroup\$ – Brian Drummond Feb 3 '16 at 16:51
  • \$\begingroup\$ Could you explain a bit? \$\endgroup\$ – zud Feb 3 '16 at 17:05
  • \$\begingroup\$ Could you add an opamp to the circuit? \$\endgroup\$ – Voltage Spike Feb 3 '16 at 17:41
Yes, it will slow down the response (assuming the load presented by your sense circuit is still "high" compared to 1 MΩ). As far as AC circuits go, the junction capacitance of the photodiode is in parallel with the resistor, forming a low pass filter.
Increasing the resistance may also increase the noise, as the Johnson noise of the resistor goes as
$$\bar{v_n^2} = 4 k_B T R$$
  • \$\begingroup\$ Isn't the junction capacitor in series with R1 here? \$\endgroup\$ – zud Feb 3 '16 at 17:05
    \$\begingroup\$ Not in terms of what signal gets to whatever's connected to the output. Remember that a power supply is an ac ground. \$\endgroup\$ – The Photon Feb 3 '16 at 17:07
