Recently, I got a low noise amplifier (i.e., ZFL-1000LN+ from MiniCircuits, http://194.75.38.69/pdfs/ZFL-1000LN+.pdf) with two wires already soldered in the turrent terminal pins. Today I have been trying to use it, but unfortunately it did not work. I connected the wire soldered in the GND pin to the GND point in my power supply and the other to the possitive connection. I was wondering if is it that the correct way or not.
Thanks in advance.
  • \$\begingroup\$ Does your power supply have +V, 0V and a separate ground? If so, you also need to connect 0V to Ground on the power supply. \$\endgroup\$ – Brian Drummond Feb 5 '16 at 14:09
  • \$\begingroup\$ Are you familiar with impedance matching? \$\endgroup\$ – Mast Feb 5 '16 at 14:09
    \$\begingroup\$ "unfortunately it did not work" - what precisely does that mean. If you went to the doctor and said ONLY that you were ill, he'd show you the door to leave. \$\endgroup\$ – Andy aka Feb 5 '16 at 14:11
  • \$\begingroup\$ it means that I had no output in the oscilloscope, no signal \$\endgroup\$ – Engineer 007 Feb 5 '16 at 14:12
    \$\begingroup\$ Here's a bench power supply, now what terminals did you use: i.stack.imgur.com/q4Lid.jpg - just state the colours to make it easy. \$\endgroup\$ – Andy aka Feb 5 '16 at 14:15
I used the red and the one in the middle (between black and red)
Use the red and black terminals. If you need to use green (to earth your set-up) then it's normal to connect it to the black terminal.
  • \$\begingroup\$ This hit me as a newbie too. Pretty bad UI design really, although a common one. \$\endgroup\$ – pipe Feb 5 '16 at 14:49
  • \$\begingroup\$ @pipe It's a matter of convention. \$\endgroup\$ – Mast Feb 5 '16 at 14:50
    \$\begingroup\$ @pipe: only if you have no clue about what gnd is \$\endgroup\$ – PlasmaHH Feb 5 '16 at 14:51
  • \$\begingroup\$ @PlasmaHH There's no reason for the earth connection to be positioned in between positive and negative, especially not when bipolar supplies are common enough. \$\endgroup\$ – pipe Feb 5 '16 at 14:55
  • 4
    \$\begingroup\$ @pipe - putting the ground between the + and - makes it convenient to tie either output to ground, as necessary. \$\endgroup\$ – WhatRoughBeast Feb 5 '16 at 15:03
