TL;DR: I can open screen
or putty
session in terminal to the /dev/ttyUSB0
, but characters transmitted are invisible. What could be the possible issue ?
I have PICDEM board with PIC18F87J11 and PIC18F8722 microcontrollers, connecting the board through serial to USB cable to my Ubuntu Linux laptop. The code in the microcontroller is supposed to transmit any character typed on the keyboard back to the console. This works alright with Windows 7 computers and putty. With Ubuntu - there is connection established in screen or putty, but the output is invisible - only the cursor continuously moves upon each keypress (which is the same behavior with Window 7).
Doing hexdump
reveals the following:
skolodya@ubuntu:$ sudo hexdump -c /dev/ttyUSB0
[sudo] password for xieerqi:
0000000 \b \b \b \b \b \b \b \b \b \b \b \b \b \b \b \b
0001900 \b \b \b \b \b \b \b \b \b \b \b \b \b \b \n \n
0001910 \n \n \n \n \n \n \n \n \n \n \n \n \n \n \n \n
cat /dev/ttyUSB0
reveals that characters are there, except show up in the caret notation, ^H
, ^E
, like that.
The code on the microcontroller itself doesn't reveal any hints of issue. The char array rxBuffer receives its characters from RCREG1
like so rxBuffer[rxCount] = RCREG1
Additional Info(as requested):
Currently the code is spitting out "HelloWorld string" (TXREG1 = txStr[txCount]
Output of hexdump -C /dev/tty | head -n 10
skolodya@ubuntu:$ hexdump -C /dev/ttyUSB0 | head -n 10
00000000 0f 01 17 0f 09 0c 0a 08 15 0c 0c 0f 01 17 0f 09 |................|
00000010 0c 0a 08 15 0c 0c 0f 01 17 0f 09 0c 0a 0f 01 17 |................|
00000020 0f 09 0c 0a 08 15 0c 0c 0f 01 17 0f 09 0c 0a 08 |................|
00000030 15 0c 0c 0f 01 17 0f 09 0c 0a 0f 01 17 0f 09 0c |................|
00000040 0a 08 15 0c 0c 0f 01 17 0f 09 0c 0a 08 15 0c 0c |................|
00000050 0f 01 17 0f 09 0c 0a 0f 01 17 0f 09 0c 0a 08 15 |................|
00000060 0c 0c 0f 01 17 0f 09 0c 0a 08 15 0c 0c 0f 01 17 |................|
00000070 0f 09 0c 0a 0f 01 17 0f 09 0c 0a 08 15 0c 0c 0f |................|
00000080 01 17 0f 09 0c 0a 08 15 0c 0c 0f 01 17 0f 09 0c |................|
00000090 0a 0f 01 17 0f 09 0c 0a 08 15 0c 0c 0f 01 17 0f |................|
The output of stty -aF /dev/ttyUSB0
skolodya@ubuntu:$ stty -aF /dev/ttyUSB0
speed 9600 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^H; eof = ^D; eol = <undef>;
eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R;
werase = ^W; lnext = ^V; flush = ^O; min = 100; time = 2;
-parenb -parodd cs8 -hupcl -cstopb cread clocal -crtscts
-ignbrk brkint ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl ixon -ixoff
-iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon iexten -echo echoe echok -echonl -noflsh -xcase -tostop -echoprt
echoctl echoke
Update: Trying out different computer with Ubuntu 14.04 32 bit didn't work either , same result
Update 4/20:
I've placed very simple code into the main
while (1) {
while (!PIR1bits.RC1IF); //Wait for a byte
sprintf(txStr,"%X",RCREG1);
LCDWriteLine(txStr,0);
continue;
It's supposed to show the hex value of RCREG1
on LCD screen. For a
letter typed on keyboard windows produces 61 as expected, but on Linux I get E1
. Oddly enough, the last 4 bits are correct regardless of what I type. But for top 4 i get values usually from D
to F
. So for hex value 62 , I get E2
hexdump -C
that is a capitalC
? \$\endgroup\$ – jippie Feb 5 '16 at 18:15stty -aF /dev/ttyUSB0
? \$\endgroup\$ – jippie Feb 5 '16 at 18:17
