In the diagram above I want to know the value and the rating of the capacitor that should be used for good rectification
The Line to Line voltage is 400 , and by relation
Vdc =(3√2 VL)/pi=(3√2 x 400)/pi = 540 V
The ballast load has the power rating of 32KW .
This gives me the current of 55A dc . How can I translate this to the capacitance value ?
One other Question . The generator has 3 phase wires and one neutral but the rectifier takes in three phase wires . Should I connect the neutral to this rectifier ? probably at the anode side of lower cathodes ?
Thank you
