Hello this is my first post here, I have some code that I've written that I'm having trouble with. I was hoping I can get some help.
I'm having some issues with my VHDL code for a 4x4 multiplier.
The schematic I'm using is below: 4x4 Multiplier
Running a Syntax check goes through just fine but I get the following error:
ERROR:HDLCompiler:1029 - "T:/Multiplier/mult.vhd" Line 26: No index value can belong to null index range
ERROR:Simulator:777 - Static elaboration of top level VHDL design unit mult in library work failed
I was able to find something similar to the first Error: https://forums.xilinx.com/t5/Simulation-and-Verification/HDLCompiler-error-1029-in-a-XilinxCoreLib-VHDL-file/td-p/153914
and he was able to fix his error by changing the size of his std_logic_vector
But I've used up all of my vector assignments and all of my signals are defined for my sumouts and carrys. The half adder and full adder source codes attached to the project were tested and working.
Any idea? The code is below. Please and thank you! I'm new here, though I've one my research and came up unsuccessful.
--4x4 Multiplier
library ieee;
use ieee.std_logic_1164.all;
entity mult is
port (x,y:IN std_logic_vector (3 downto 0);
        p:OUT std_logic_vector (7 downto 0));
end mult;
architecture mult_beh of mult is
component ha
    port(a,b: IN std_logic;
                c,s: OUT std_logic);
end component;
component fa
    port(a,b,cin: IN std_logic;
                cout,sum: OUT std_logic);
end component;
signal andgate: std_logic_vector(15 downto 0);
signal sumout: std_logic_vector(11 downto 0);
signal carry: std_logic_vector(11 downto 0);
begin
    andgate(0) <= x(0) and y(0);
    andgate(1) <= x(1) and y(0);
    andgate(2) <= x(2) and y(0);
    andgate(3) <= x(3) and y(0);
    andgate(4) <= x(0) and y(1);
    andgate(5) <= x(1) and y(1);
    andgate(6) <= x(2) and y(1);
    andgate(7) <= x(3) and y(1);
    andgate(8) <= x(0) and y(2);
    andgate(9) <= x(1) and y(2);
    andgate(10) <= x(2) and y(2);
    andgate(11) <= x(3) and y(2);
    andgate(12) <= x(0) and y(3);
    andgate(13) <= x(1) and y(3);
    andgate(14) <= x(2) and y(3);
    andgate(15) <= x(3) and y(3);
    --Gates
    ha0: ha port map(s => sumout(0), a => andgate(1), b => andgate(4), c => carry(0));
    fa0: fa port map(sum => sumout(1), a => andgate(2), b => andgate(5), cout => carry(1), cin => carry(0));
    fa1: fa port map(sum => sumout(2), a => andgate(3), b => andgate(6), cout => carry(2), cin => carry(1));
    ha1: ha port map(s => sumout(3), a => carry(2), b => andgate(7), c => carry(3));
    ha2: ha port map(s =>sumout(4), a => sumout(1), b => andgate(8), c => carry(4));
    fa2: fa port map(sum => sumout(5), a => sumout(2), b => andgate(9), cout => carry(5), cin => carry(4));
    fa3: fa port map(sum => sumout(6), a => sumout(3), b => andgate(10), cout => carry(6), cin => carry(5));
    fa4: fa port map(sum => sumout(7), a => carry(3), b => andgate(11), cout => carry(7), cin => carry(6));
    ha3: ha port map(s => sumout(8), a => sumout(5), b => andgate(12), c => carry(8));
    fa5: fa port map(sum => sumout(9), a => sumout(6), b => andgate(13), cout => carry(9), cin => carry(8));
    fa6: fa port map(sum => sumout(10), a => sumout(7), b => andgate(14), cout => carry(10), cin => carry(9));
    fa7: fa port map(sum => sumout(11), a => carry(7), b => andgate(15), cout => carry(11), cin => carry(10));
    --Assigning p values
    p(0) <= andgate(0);
    p(1) <= sumout(0);
    p(2) <= sumout(4);
    p(3) <= sumout(8);
    p(4) <= sumout(9);
    p(5) <= sumout(10);
    p(6) <= sumout(11);
    p(7) <= carry(11);
end mult_beh;
  • \$\begingroup\$ Post code for components fa and ha. We don't know what they are! \$\endgroup\$ – Jakub Rakus Feb 7 '16 at 21:48
  • \$\begingroup\$ There you go! :) This is the working code \$\endgroup\$ – Billy Bob Feb 9 '16 at 3:43
You defined all your vector ranges in the wrong direction. If you want to use downto then the left index must be greater than the right index, e.g.:
Or change the direction to to in your code to number the bits in ascending order.
  • \$\begingroup\$ Thank you! That fixed everything. Test bench runs and results are as expected. \$\endgroup\$ – Billy Bob Feb 7 '16 at 7:30
