I am trying to understand the concept of modeling a circuit from a FSM in Verilog.
I have tried to write down the procedure that I have used in the image below just to make sure that I did it right:
Based on the solution the circuit is as below:
The Verilog code I have developed is:-
//module bit stream generator
module generator(
clk,
stream //generated stream
output stream;
input clk;
reg c;
wire stream;
assign stream=c;
initial
begin
c=1'd0;
end
always@(posedge clk)
begin
//c=!c;
c = {$random} %2;
//$display("a= %b",c);
end
endmodule
//module D flip flip
module d(q_w,q0_w,d,c);
output q_w,q0_w;
input c,d;
//wire c;
reg q,q0;
wire q_w,q0_w;
assign q_w=q;
assign q0_w=q0;
initial
begin
q=1'b0; q0=1'b1;
end
always @ (posedge c)
begin
q=d;
q0= ~d;
end
endmodule
//module sequencedetector
module sequencedetector(
clk,
x, //input bit stream
out //output from sequence detector
input x,clk;
output out;
wire x,y0,y_0,y1,y_1,g12,g32,g2d1,out;
d dff1(.q_w(y1),.q0_w(y_1),.d(g2d1),.c(clk)); //flip flop D1
d dff0(.q_w(y0),.q0_w(y_0),.d(x),.c(clk)); //Flip Flop D2
and gate1(g12,x,y0);
or gate2(g2d1,g12,g32);
and gate3(g32,y1,y0);
and gate4(out,x,y_0,y1);
endmodule
//module sequencedetector testbench
module sequencedetector_tb;
reg clk;
wire out,x;
sequencedetector UUT(
.clk(clk),
.x(x),
.out(out));
generator UUTgen(
.clk(clk),
.stream(x));
initial begin
clk=1'b0;
//stream=1'b0;
//=1'b0;
end
initial
begin
$dumpfile ("counter.vcd");
$dumpvars(0);
end
always
begin
#20 clk=!clk;
end
initial
begin
#20000 $finish;
end
endmodule
But sadly the I the output is not as expected The circuit does not detect any seqience as the output is always LOW. Am not able to upload the GTKwave snapshot in want of sufficient reputation.
Any help is highly appreciated
EDIT
Just figured out that in the code for the flip Flop the output(q) was not following the input(d) whenever the input bit changed for one cycle only, probably because the sampling was being done at same instance as shifts were happening(in the bit stream). This code was requiring the changed bits to sustain atleast 2 cycles to be followed by the flip flop output. Introduced a delay of 2 cycles in the flip flop code and the output is as expected.
begin
#2 q=d;
q0= ~d;
end
The problem now is what should I do if I need to implement the Verilog code on a an actual hardware. I mean what is the alternate of delay (#2) if i need to make a synthesizeble code (definitely not multitude of gates) but some standard hardware friendly verilog function, maybe.
