I have a PCB which has a footprint for an IC. This IC is a TQFP package and has about 144 pins. However, not all the pins are brought out on the PCB. I am ready to desolder the IC from the PCB and put it on another PCB which breaks out the required pins. However I am still having some questions as to how to reattach the PCB back to the original one? IS there any other way to get access to pins on the IC without making another PCB? The original PCB has a lot of other connections, so I have to attach it back
    \$\begingroup\$ For tqfp you could solder 30awg wires straight to the leads. It takes good hands and eyes, but is possible- i did it a couple of times. \$\endgroup\$
    – user76844
    Feb 7, 2016 at 15:29
  • \$\begingroup\$ @GregoryKornblum That is kind of hard for me to do. May end up doing it, but want to stay away from it \$\endgroup\$
    – red car
    Feb 7, 2016 at 15:46
  • \$\begingroup\$ Ask someone who can. Do you have an assembly factory nearby? Usually there should be a skilled soldering worker. \$\endgroup\$
    – user76844
    Feb 7, 2016 at 15:48
    \$\begingroup\$ If you can't solder a few wires to TQFP pins how are you going to solder every one of the 144 pins from the IC to the breakout board? Chances are that will be more difficult, especially for a previously used IC since the pins will have solder on them and will likely be somewhat misaligned with each other. Personally I would use a bit finer than AWG30 if possible- because it looks like a telephone pole under the microscope- it's the same diameter as the width of the pin, and much thicker. \$\endgroup\$ Feb 7, 2016 at 16:06
    \$\begingroup\$ No objections, 34awg will work too :) \$\endgroup\$
    – user76844
    Feb 7, 2016 at 18:44
Seems you have 2 options:
Option A. Remove the TQFP from the PCB using a hot air tool, taking care not to damage the TQFP by excessive heat or twisting pins. Don't damage the PCB by lifting traces. And don't dislodge other parts that are near to the TQFP. Then solder the TQFP to your 2nd PCB, using a very fine tipped soldering iron, fine solder and lots of flux. Realize that you have soldered the TQFP on the wrong way round, so remove it again using the hot air tool, and solder it on the correct way. Without damaging it. Then use fine wire to connect most of the 144 pins from your 2nd PCB back to the first. If your TQFP has a crystal, any high speed connections or sensitive analog inputs then these quite probably are not going to work correctly now. Even if it does work the whole thing is going to be so fragile that its not going to work for long.
Option B. Use some fine wire to connect directly to the pins of the TQFP.
