Ive been reading up on capacitors. But most stuff is over my head. I'm considering a system with the following attributes:
Capacitor: 12 VDC, 0.5 Farad. Power supply: 5 VDC, 1 amp
What will the power output of the capacitor be?
Based on I=C(dV/dT)
C = 0.5 Farad. dV = 5 VDC. dT = 1 second.
Then I = 2.5 amps
So the power output will be 12.5 watts with a 5 watt input.
This doesnt seem right to me. Is this correct?
    \$\begingroup\$ Watt is energy per second. You can't increase energy out of nowhere, but you can decrease time. I'll see if I can put it in a proper answer, here you have a hint to work with :) \$\endgroup\$ – Mołot Feb 7 '16 at 19:04
  • \$\begingroup\$ No, if the PSU is limited to 1A. then you cat compute dV/dT =I/C = 2V per second. So it takes 2.5 seconds to charge to 5V. \$\endgroup\$ – Brian Drummond Feb 7 '16 at 21:14
    \$\begingroup\$ You can't have it both ways. If your input supply is limited to 1A (5W) then your cap will take 2.5 seconds to charge, not 1 second. If you're getting 2.5A out of your supply to charge the cap in 1 sevond then its delivering 12.5W, not 5W. \$\endgroup\$ – brhans Feb 7 '16 at 23:32
Its correct..... Capacitor can discharge very rapidly thus able to deliver higher output power. However, their input power could be very less depends on the current capability of the power supply that charges it.
If look closely at xenon flash lamp in cameras, most cameras operates on tiny battery but xenon tube operated from them flashes at kilowatts. This is true because a high voltage capacitor inside the unit is charged to +350V by a boost converter. The capacitor takes few seconds to be fully charged. During flashing the entire charge is dumped into xenon tube in mere milliseconds.
Power is actually the rate of energy conversion. Capacitors can do this very fast thus can exhibit very high output power.
This is why capacitors are also known as condensers or accumulators.
| improve this answer | |
The answer provided is somewhat correct, but doesn't make clear that the power delivered to the load is continually varying.
Take this circuit:
V1 is a pulsed waveform going between 0V and 12V, so C1 is charged to nearly 12V. The resulting waveforms when V1 goes to 0V:
Notice that the voltage starts at 11A and at 120W, but quickly drops down to nearly 0A/0W within that one second. If you took the average power over the 3s time period, you probably wouldn't even be at 10W. When you are talking about capacitors and current, you are nearly always talking about averages (or RMS values) on a periodic waveform. Rarely are you talking about the peak power.
Your numbers:
Based on I=C(dV/dT)
Then I = 2.5 amps
This is only true for an instant and is never true again until the capacitor is recharged.
