I am making a small DIY project to operate my wired landline phone (twisted copper cable) using my mobile phone. Use cases:
  • Dial number on landline via mobile device.
  • Receive incoming landline calls via mobile.
I plan to use RaspberryPi. What device can I use to intercept calls on my wired phone and do two way manipulation? (I assume it will be an analog to digital and vice versa device, similar to a modem.)
  • \$\begingroup\$ As Jasen has answered, an Asterisk setup is what you want. You're basically setting up a pbx. \$\endgroup\$ – Passerby Feb 8 '16 at 13:14
you want an FXO with USB or ethernet connectivity, probably you want asterisk support too.
| improve this answer | |
