-1
How does it happen if I use an inverted transformer in a two switch forward converter? please consider practical conditions.
regards. ras
two switch forward inverted transformer
  • \$\begingroup\$ Your question ist fairly unspecific. Could you try to narrow your Problem, please? As it stands, it looks like you're trying to find a textbook explanation about SMPS design / 2SF converters, which is not a very good fit for this site. \$\endgroup\$
    – zebonaut
    Feb 9 '16 at 6:31
  • \$\begingroup\$ i have made two switch forward converter but incorrectly the secondary transformer has been wounded inversely! ( as the schematic shows ). so does the circuit work? \$\endgroup\$
    – Rasool
    Feb 9 '16 at 8:34
with it set-up like that the transformer is being used as a coupled inductor, as the flux decays the output diode is forward biased and conducts, so you essentially have a flyback that's limited to the supply voltage instead of a forward converter.
