I have this piezo vibration sensor module from Grove: http://www.seeedstudio.com/wiki/Grove_-_Piezo_Vibration_Sensor sensor
Using this sensor and an arduino device I want to measure two things:
  • amplitude (negative and positive)
  • vibration frequency
Is it possible to measure the negative amplitude with this board? The analog input of an arduino board use a 10bit ADC. So we have 1024 values available. Is it possible to use the value 0-511 for negative measurement and 512-1023 for positive? Normally I would use a voltage devider to set an offset to the negative sensor values. But in this case I don't know how the board is handling negativ sensor values.
Here is the board circuit:
For frequency measurement I want use the amplitude values and do a FFT.
is there any chance to get the negative values?
With this circuit you even can't get the positive values, only a digital signal that tells whether the input signal goes above some fixed threshold level. The threshold can be adjusted by R6.
The LM293 is a comparator that checks whether the negative input (pin 2) is higher than the positive input (pin 3). So the output is purely digital (i.e. 1 or 0).
You could, however, pick up an analog signal at the output of the OpAmp U1B (pin 7).
  • \$\begingroup\$ Oh Ok, thanks! So with the output of that module I can just see if there is a vibration or not. Nothing more. Ok, then I need to read just the vibration sensor. \$\endgroup\$
    – CPA
    Commented Feb 9, 2016 at 9:25
