Is it good to use one UART interface on MCU, RX_UART for receiving data from RS422 receiver and TX_UART for transmitting the same data to the RS232 and RS422 transmitter? I am trying to use UART as "signal splitter", because I want to use my rs422 input signal and forward it to rs232 and other rs422.
EDIT: I can not ask another question, and don't know how to edit others to be allowed to ask again, but I would like to know this:
Why JTAG connectors use 20, 14 or 10 pins (standard), when only 7 is required (minimum, TDI, TDO, TMS, TCK, NTRS, GND, VDD)?
closed as unclear what you're asking by Olin Lathrop, PeterJ, Daniel Grillo, nidhin, Scott Seidman Feb 14 '16 at 14:40
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ That seems a little unclear. Your finished system will have what inputs and outputs? \$\endgroup\$ – Jasen Feb 9 '16 at 11:02
  • \$\begingroup\$ It would have RS422/485 input (one receiver), and outputs RS422 and RS232 (one driver for each). \$\endgroup\$ – Haris778 Feb 9 '16 at 11:34
    \$\begingroup\$ Why do you need a UART at all? Just connect the receiver directly to the two drivers. \$\endgroup\$ – Dave Tweed Feb 9 '16 at 12:34
  • \$\begingroup\$ I could do that, but I also need received data to process in MCU. Maybe I should connect both drivers and MCU to receiver. Thank you. \$\endgroup\$ – Haris778 Feb 9 '16 at 12:45
    \$\begingroup\$ Right, that's what I would do. One RS422 differential receiver connected to RS422 transmitter, RS232 transmitter, and the Rx input pin on your MCU. \$\endgroup\$ – Alexxx Feb 9 '16 at 14:59
no problem connecting a output to several inputs is normal, the limit is the fan out If you use MAX488 as a repeater of RS422 (connect DO to DI), you can connect a MAX232 Tx Input to the TTL side of MAX488 (DO + DI).
