On the readme page of https://github.com/pwarren/rtl-entropy, it says:
If you're serious about the cryptographic security of your entropy source, you should probably short, or put a 50 Ohm load on the antenna port, and put the whole assembly in a shielded box. Then you're getting entropy from the thermal noise of the amplifiers which is much harder to interfere with than atmospheric radio.
How do I put a 50 Ohm load on that port? Do I just put a resistor of 50 Ohm on the port? Can I safely short the port (connecting both parts with a copper wire)?
