I know it is some sort of wide question, but nowday I usually only see digital oscilloscopes around. I want to know if their digital nature will affect the accuracy of measurements? (Something like digitization error in sampling signals). Or asking other way are they any specific applications which accurate measurement requires using only analog ones in current time? I guess flexibility of digital oscilloscope grows trend to using this type of oscilloscopes, but I will be happy if you correct me.
  • 8
    \$\begingroup\$ A more accurate analogue scope is more accurate than a not so accurate digital oscilloscope, while a more accurate digital scope is more accurate than a not so accurate analogue scope. Compare specs, not technologies. \$\endgroup\$
    – PlasmaHH
    Feb 9, 2016 at 14:19
    \$\begingroup\$ A friend who teaches undergraduate and post graduate electronic engineering complains that the users of oscilloscopes don't understand the limitations. He has said "students happily sample signal frequencies that are 'aliased' by digital scopes sampling rate, and expect their analysis and calculations to be correct". He retained quite old analogue scopes for a long time. He believes students make fewer mistakes with analogue than digital. But it is less about the technology, and more about the users misunderstanding the technology. \$\endgroup\$
    – gbulmer
    Feb 9, 2016 at 14:20
  • \$\begingroup\$ The time base on the digital 'scope will be more accurate. \$\endgroup\$ Feb 9, 2016 at 14:23
    \$\begingroup\$ @gblumber I have digital and analog scopes just for this reason; I can show the same signal presented differently. I wish that I could up vote your comment. \$\endgroup\$
    – b degnan
    Feb 9, 2016 at 14:25
    \$\begingroup\$ @ScottSeidman - fair points. IIRC, logistics/availability were part of what forced them to move on. Also, they bought a few very good 'scopes, as well as classroom-sets, so they could at least demonstrate issues, and have equipment for student projects if they needed tools to debug their process. \$\endgroup\$
    – gbulmer
    Feb 25, 2016 at 0:12
6
The modern digital oscilloscopes are sophisticated analog beasts!
Most of the modern day high speed digital and analog equipment, such as computer interfaces (USB, SATA, Gigabit Ethernet) are tested, designed and refined using digital oscilloscopes. Even many SoCs containing complex analog and digital peripherals are validated using digital oscilloscopes. For example USB 3.0 can have speeds up to 5Gig bits per second. The interfaces are literally probed by digital oscilloscope inputs and careful test setups are built around them.
Even high speed analog blocks such as ADCs, Amplifiers, Filters and Oscillators are tested using DSOs.
However from a purchase point of view, these are very expensive oscilloscopes. For the highest analog bandwidth available, the boxes from companies such as LeCroy (part of Teledyne now), Keysight (Changed from Agilent's T&M division), Rhode & Schwartz and Tektronix, may cost a Ferrari!
But for most of hobby use, student laboratory or even a decent embedded testing there are value-for-money oscilloscopes from above companies and many other from around the world. There are also PC based USB oscilloscope products (BitScope, Picoscope or USBee).
Digital oscilloscopes exists because they work! And engineers use them! I use them!
Most of the time, we expect more from a box and potentially use an unsuitable signal for analysis. A high speed square pulse stream on a lesser bandwidth oscilloscope will look smoothed out! Or even as a sine-wave! Because all the higher frequency part of the signal is filtered out on channel.
These are few questions you may want to ask yourself before choosing an equipment.
  • Ideally every signal is of infinite bandwidth. Only that the higher harmonics are very feeble. So choose the "Analog bandwidth" of the scope based on your signal.
  • Try to use the full dynamic range of the scope (Full bit resolution vs. full scale). If your interest is about superimposed parts of a signal, like that sharp glitch on a sinewave output of a switched power supply, go for higher ADC resolution scopes.
  • If the signal is small, the scope will amplify it. If the signal is large the scope will attenuate it to suite the full swing of the internal ADC. Some times you may want to use the auto-scale feature of the scope.
  • If the signal is too small amplitude, then amplifying it will also amplify some noise. If the signal has large glitch, then attenuating it will reduce its details.
We should also look into the merits of Digital Vs. Analog scopes
  • Most DSOs have sophisticated Analog Front Ends (AFE). Which is again software controlled and offers extra leverage based on signal. Signal conditioning, amplifying and even isolating are handled in digitally controlled AFE.
  • Next to AFE is the heart of a digital scope, which is a high-speed ADC. This technology has improved leaps and bounds in the last decade.
  • There is a ping-pong or daisy-chained RAM buffering of ADC samples before they are pushed to a dedicated computer. If you know DSP, you will know the 'value' of digital samples!
  • The raster / rendering of digital signals on a decent UI actually gives ability to have multiple cursors both horizontal & vertical, easy scale adjustments, visualization, attached measurements and mutiple channels in one go!
  • I think multiple channel, channel math&logic, advanced triggering capabilities are the most useful features of a DSO.
However if you admire pure analog signals, directly imposing themselves on a phosphor screen, nothing wrong with that too!
He has said "students happily sample and measure signal frequencies that are 'aliased' by digital scopes sampling rate. They expect their analysis and calculations to be correct". He retained quite old analogue scopes for a long time. He believes students make fewer mistakes with analogue than digital.
I guess part of the problem is the very helpful, apparently definite, measurement that some digital scopes give. If a user doesn't think about what is happening, those displays are quite seductive, but misleading (the illusion of accuracy).
But it is less about the technology, and more about the users misunderstanding the technologies limitations and capabilities.
I would expect the spec of a 'scope to be a good reflection of the equipment capability because they are (mostly) designed to be read by people who understand what the spec means.
    \$\begingroup\$ +1 for "But it is less about the technology, and more about the users misunderstanding the technologies limitations and capabilities." A tool is only reliable if the user understands the tool he's using. \$\endgroup\$ Feb 9, 2016 at 14:53
    \$\begingroup\$ +1. Digital scopes cheerfully tell lies. I've seen someone staring at a 1Hz waveform wondering why it wasn't 10kHz. Having chosen such a slow timebase, the scope set its sampling rate to 10kHz (+/- 1Hz)... OTOH they are often far more convenient, and now usually cheaper than a decent analog scope... \$\endgroup\$
    – user16324
    Feb 9, 2016 at 15:19
