This is an 11-way connector pair from inside a standalone induction hob. It comprises a cable-mounted female part and a PCB mounted male part.
(Corrected due to sloppy original measuring - thanks @Passerby) Pitch is 2.5mm and pin length appears to be around 3.3mm. The female part is about 4mm wide and 8mm tall. Does anyone recognise this system?
