I'm looking for a small rotary switch but don't know the terminology to find what I'm looking for. To be honest I'm not sure they make what I'm looking for. The closest I have found is this, a rotary dip switch.
But these encode the output. What I want is to have 8 input lines and 1 output line so the user and select one of the 8 input lines. I could do this with the dip switch, a decoder IC and a AND logic IC but I would really rather not need to have additional ICs.
I just need a small switch I can solder to a PCB and to let the user select one of 8 lines.
You want a SP8T selector switch. For example, this one, but you should be able to find others now that you know what to call it.
  • \$\begingroup\$ It's the same one I found trough the mouser search tool. How can there be just one suitable part? \$\endgroup\$
    – jms
    Feb 10, 2016 at 18:18
  • \$\begingroup\$ It's a rather rare requirement, but you can find some smallish through-hole rotary switches and at least one 10 position slide switch. \$\endgroup\$ Feb 10, 2016 at 18:29
  • \$\begingroup\$ @jms Here's a 3-position non-encoded switch. \$\endgroup\$ Feb 10, 2016 at 19:38
  • \$\begingroup\$ @NickAlexeev I was searching for 8pst specifically, and got surprised about the lack of variety. \$\endgroup\$
    – jms
    Feb 10, 2016 at 21:10
  • \$\begingroup\$ @jms And, of course, if that one manufacturer decides to end production (and they will some day), you've got a real problem. Nothing else out there looks to be remotely as small. \$\endgroup\$ Feb 10, 2016 at 21:17
Just use a DIP switch with one side of all the DIP switches connected together into a common: as long as you can deal with use cases where more than one DIP switch is activated.
