9
I want to use a multi-conductor cable for a few different circuits. What do I need to know about interference between circuits within a multi-conductor cable?
Some of the wires will carry stepper motor coil supply and return. I suspect this will emit a lot of EMF due to large, rapidly changing currents, and should probably be shielded.
Other wires will carry optical switch supply, return, and output. This circuit is probably tolerant to noise and doesn't make much of it either.
Others wires could carry high-speed digital data. These circuits are probably susceptible to noise and might make some as well.
Can I run these all in the same cable? What else might I need to consider?
EDIT: Let's assume I'm talking about using a cable that has a single shield around all of the wires, instead of individually shielded bundles of a few wires.
  • \$\begingroup\$ one thing that's sometimes done is to make every other wire a ground wire, specifically, an actual voltage reference ground and not a current return 'ground'. i guess the idea is to provide some isolation between adjacent conductors. \$\endgroup\$
    – JustJeff
    Nov 2, 2011 at 1:26
  • \$\begingroup\$ @JustJeff If that works, I could see it being useful for a ribbon cable, but not just any amorphous multi-conductor cable. \$\endgroup\$ Nov 2, 2011 at 3:25
    \$\begingroup\$ indeed. Guess I just assumed ribbon cable. So do you have twisted pairs in your cable, or is it just straight parallel conductors? \$\endgroup\$
    – JustJeff
    Nov 2, 2011 at 10:49
  • \$\begingroup\$ @JustJeff I hadn't considered whether or not I should use twisted pairs; I guess that's part of the question ;-). \$\endgroup\$ Nov 2, 2011 at 16:49
There are two issues with crosstalk between conductors of a cable: capacitive coupling and inductive coupling.
Inductive coupling happens because current flowing thru a wire creates a circular magnetic field around that wire. This also works in reverse. If a wire is subjected to a changing circular magnetic field around it, a voltage will be induced. Therefore, if one wire is carrying a changing current and another wire is close enough so that part of the resulting circular magnetic field also surrounds this second wire, then a voltage is induced in the second wire.
The most effective way to combat this problem is to make sure a equal and opposite return current flows such that the magnetic fields from the two currents cancel out. The best way to ensure this is coaxial cable. Outside the cable, the two equal and opposite currents cancel and there is no net magnetic field.
Inside a multi-wire cable like you describe, this is usually done with twisted pair. At any one point, the two conductors are next to each other. Far enough away the two currents cancel, but up close they don't. Another wire running closer to one wire of the pair will preferentially pick up signal from that wire. This is why the wires are twisted together. A straight wire next to a twisted pair will alternately be nearer one conductor then the other of the twisted pair. Each induces the opposite voltage since the direction of current is opposite in the two wires of the twisted pair. However, these average out to zero over any whole number of twists. In a long enough cable they usually average out well enough.
There is another problem with twisted pair though. Suppose you have multiple twisted pair in the same cable, which is probably the case in the cable you describe. If the twists of one pair are in sync with the twists of another pair, then the induced voltage no longer cancels out in the long run. This is why cables with multiple twisted pair usually have a different twist pitch for each pair. Let's say one pair has 11 twists/foot and another 13 twists/foot. Over any one foot the induced coupled voltage cancells out again. Take a look at the CAT5 cable spec and you will see the different twist pitches for each of the four pairs are carefully specified.
Capacitive coupling is because there is some finite capacitance between every two conductors in the universe. For things far enough apart this can usually be ignored. However, different conductors in a multi-conductor cable are up against each other for a long distance such that capacitive coupling can't be ignored. The best defense against capacitive coupling is a shield, but those are expensive and you say your cable doesn't have any internal shields. Twisted pair again helps here. There will still be capacitive coupling between pairs, but with the right twisting strategy as described above there won't be much preferential coupling to one conductor of the pair. In other words, twisting will cause all the coupling to be common mode with the differential mode mostly cancelling out.
So to finally get to some kind of answer, make sure each signal is carried by a separate twisted pair with the forward and return current of that signal all being carried by that pair. Then treat any signal as differential. Realize there will be common mode noise added to each pair and deal with it accordingly. The external world will also have noise, and due to twisting, this noise will show up as common mode on each pair. 10 base-T and later ethernet, for example, is transformer coupled at each end partly for this reason and also to avoid ground loops.
All that said, I think running stepper motor coil currents thru the same cable as signals is just nuts. This is going to cause trouble. I would seriously look into sending control signals and power for the steppers, but put the stepper drivers close to the stepper motors. That also allows for a local power reservoir cap to make the supply low impedance again after the long cable run. Having the resistance and inductance of the cable between the stepper driver and the stepper motor is asking for more trouble.
  • \$\begingroup\$ Excellent response. Thank you for the insight. In regard to your suggestion about placing the stepper drivers close to the motors: unfortunately packaging constraints prevent this in some applications (such as a device I worked on). For compactness, the drivers were integrated into the controllers, and there was no room to place them on or near the motors themselves. It wasn't a problem in that case, but the signals were on separate cables. \$\endgroup\$ Nov 2, 2011 at 16:43
  • \$\begingroup\$ (They were also pretty small steppers which probably helped some) \$\endgroup\$ Nov 2, 2011 at 16:51
