I am currently doing a design where I basically have two different types of (digital) signals. The first signal group is fully differential (P/N pair). The other group are single ended signals referenced to ground.
I would like to transfer both these signals via Twisted Pair cabling to another board. The cable producer specifies that the twisted pair cable has a (differential) impedance of 100Ohms, which is what if perfectly fine for the differential signals.
For the single ended signals, lets assume I have an output driver impedance of 50 Ohms and an input impedance of 50 Ohms as well so what I would basically want is a cable impedance of 50 Ohms.
How is this issue addressed in the real world? Is this an issue at all? Is the differential impedance of 100 Ohms "the same" as a single ended impedance around 50 Ohms?
What I understand is that a typical coaxial cable has an impedance of around 50 Ohms, but what about single ended signals on a twisted pair cable?
