I use I2C communication with two stm8s boards.
My master code:
I2C_GenerateSTART(ENABLE);
I2C_Send7bitAddress(0x30, I2C_DIRECTION_TX);
I2C_SendData(0x61);
I2C_GenerateSTOP(ENABLE);
delay(1500);
My slave address is 0x30. I send 0x61. I analyzed stm8s master board with ossiloscope. I see from lister:
Address:30R
Data: anything
Missing ACK: X(with red background)
My signal from master board with stm8s: [![enter image description here][1]][1]
what could be the problem for missing ack? And, is it true address and data values? Thank you!
And,
My master arduino code:
Wire.beginTransmission(0x30); // transmit to device 0x30
Wire.write(0x61);              // sends one byte
Wire.endTransmission();    // stop transmitting
delay(500);
And this picture from master arduino code with ossiloscope: enter image description here
Here, adress is 30W, but adress of my stm8s master code is 30R. I changed this line of the stm8s master code:
I2C_Send7bitAddress(0x30, I2C_DIRECTION_RX);
//I2C_Send7bitAddress(0x30, I2C_DIRECTION_TX);
But adress is still 30R.
code of this line:
  * @brief  Transmits the 7-bit address (to select the) slave device.
  * @param   Address : Specifies the slave address which will be transmitted.
  * @param   Direction : Specifies whether the I2C device will be a Transmitter or a Receiver.
  * This parameter can be any of the @ref I2C_Direction_TypeDef enumeration.
  * @retval None
void I2C_Send7bitAddress(uint8_t Address, I2C_Direction_TypeDef Direction)
  /* Check function parameters */
  assert_param(IS_I2C_ADDRESS_OK(Address));
  assert_param(IS_I2C_DIRECTION_OK(Direction));
  /* Clear bit0 (direction) just in case */
  Address &= (uint8_t)0xFE;
  /* Send the Address + Direction */
  I2C->DR = (uint8_t)(Address | (uint8_t)Direction);
and
  * @brief  I2C transfer direction
  * Warning: the values correspond to the ADD0 bit position in the OARL register
typedef enum
  I2C_DIRECTION_TX = (uint8_t)0x00,  /*!< Transmission direction */
  I2C_DIRECTION_RX = (uint8_t)0x01   /*!< Reception direction */
} I2C_Direction_TypeDef;
/**************************NOW*******************************************/ I changed my stm8s I2C master code:
I2C_SendData(0x60); //I have no idea, i tried it and works for write/read selection
I2C_SendData(0x61); //my send data
delay_delay(1500);
Adress is 30W, now. It is true because i want to write to slave. Then, I saw this signal from ossiloscope:
This signal is same with Arduino master transmitter.
But, I can't see signal of the data. What could be the reason for this? Missing ACK or another thing? I don't know, but data signal is no of the arduino signal. Missing ACK?
Thank you!
    \$\begingroup\$ Your slave is supposed to be sending the ACK back to your master. Have you enabled that in your slave code? \$\endgroup\$
    – brhans
    Feb 15, 2016 at 22:26
    \$\begingroup\$ We'd need to see your slave code to know more. Your master code says I2C_DIRECTION_TX but the bus shows a read, not a write. The eighth bit of the transfer should be a 0 for TX. Also, I'm not sure you need to send a stop condition after an address NACK. \$\endgroup\$
    – Adam Haun
    Feb 15, 2016 at 22:33
  • \$\begingroup\$ I edited my post for your comment. @AdamHaun \$\endgroup\$
    – kbtr
    Feb 15, 2016 at 22:45
There are two standard formats for 7-bit I2C addresses -- 0x7F and 0xFE. It looks like I2C_Send7bitAddress() expects 0xFE format. If your actual slave address is 0x30, try sending 0x60 (which is 0x30 << 1) and see if that works.
The reason for the 0xFE format is that it lets you treat the read/write direction bit as part of the slave address, giving an 8-bit value. That's what you actually see on the bus.
  • \$\begingroup\$ Ok, i tried with online c compiler, but 0xC0 << 1 is: goo.gl/XfbymG \$\endgroup\$
    – kbtr
    Feb 15, 2016 at 23:03
  • \$\begingroup\$ Oops! It's not 0xC0, it's 0x60. You left-shift the address (0x30) by one to convert to 0xFE form, which gives you 0x60. \$\endgroup\$
    – Adam Haun
    Feb 15, 2016 at 23:19
  • \$\begingroup\$ Hello @AdamHaun, I can change write/read selection. Address(0x30) and data direction(write) are true, now. But, I can't see signal of the data. What could be the reason for this? Missing ACK or another thing? I don't know, but data signal is no of the arduino signal. Missing ACK? Thank you! \$\endgroup\$
    – kbtr
    Feb 16, 2016 at 18:33
  • \$\begingroup\$ It's almost certainly the missing ACK. The problem is probably on the slave side. \$\endgroup\$
    – Adam Haun
    Feb 16, 2016 at 19:14
