-2
I was wondering how to measure the current generated by a wind turbine?
I tried connecting the voltmeter to the metal connectors of the motor (the 2 metal parts that stick out the motor) and set my voltmeter to amperage, but it showed 0A when the motor was turning. So I attached a resistor as a load and then tried measuring the amperage, but I still got 0.
What am I doing wrong?
  • 4
    \$\begingroup\$ Do you know how to measure current of anything else? \$\endgroup\$ – Samuel Feb 17 '16 at 0:14
    \$\begingroup\$ Did you measure the voltage? how are you turning it? what kind of resistor. Please be specific. \$\endgroup\$ – Voltage Spike Feb 17 '16 at 0:15
    \$\begingroup\$ What wind generator are you using with your turbine? A DC generator can be measured one way, but an AC gen. would need a diff. measurement. \$\endgroup\$ – Robherc KV5ROB Feb 17 '16 at 0:19
  • \$\begingroup\$ I used a 3.9k Ω resistor and it is a 9-18V DC motor. I measured voltage and it was 1V. However, I measured voltage without any load. \$\endgroup\$ – user510 Feb 17 '16 at 0:28
  • \$\begingroup\$ It could be the same because there's a light internal load and 3.9k isn't enough of a diff. Or the speed is too low. Both the mechanical energy put into the motor (effectively the speed) and the load are going to affect the voltage / current. So if you're just spinning the blades for 2 cycles for only a second and you're not really loading it, you might not see much difference in output. You might need to actually get some wind moving it and use a load more like 100 R or even lower. I think you want to load it enough to the point where it actually slows down the blades slightly. \$\endgroup\$ – squarewav Feb 17 '16 at 0:41
If it's making 1V and you have a 3900Ω load, that's about 0.00025A. Not really detectable with your average multimeter. Also you need to put the multimeter in series. Like this:
http://www.dummies.com/how-to/content/how-to-measure-current-on-an-electronic-circuit.html
Motor on wind turbine need some speed, low speed generator could not make any power, see tag on motor . DC motor permanent magnet could work in wide range speed. Let say you need Load like bulbs or battery to check how much current its take. See tag on motor what it say.
