I'm writing a package to add supporting functions and types for creating an FIR filter. In the mult function, I'm trying to multiply two signed types, which should be supported in IEEE.numeric_std library. The error I'm getting (using Libero IDE) is:
0 definitions of operator "*" match here
Here's the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
package fir_pkg is
    constant taps : integer := 8;
    constant bit_width : integer := 8;
    type fract is array(bit_width-1 downto 0) of std_logic;
    type fract2 is array((2*bit_width)-1 downto 0) of std_logic;
    type fract_sequence is array(taps-1 downto 0) of fract;
    type fract2_sequence is array(taps-1 downto 0) of fract2;
    function mult(a,b: fract_sequence) return fract2_sequence;
end package fir_pkg;
package body fir_pkg is
    function mult(a,b: fract_sequence) return fract2_sequence is
        variable a_s, b_s:signed(bit_width-1 downto 0);
        variable seq: fract2_sequence;
    begin
        for i in a'range loop
            a_s := signed(a(i));
            b_s := signed(b(i));
            seq(i) := a_s * b_s;
        end loop;
        return seq;
    end mult;
end fir_pkg;
    \$\begingroup\$ This is complaining that there isn't a "" operator with a signature [signed, signed return fract2]. You've defined a type but provided no overload operator "" that supports the signature. That implies you might want to type convert something. \$\endgroup\$
    – user8352
    Feb 18, 2016 at 6:57
  • \$\begingroup\$ Yeah, that seems to be exactly the problem now (I've got the product on a signed variable now and am equating seq(i) in the next statement. How can I create conversion operators from signed to my custom type (still based on std_logic)? \$\endgroup\$
    – Prabhpreet
    Feb 18, 2016 at 7:04
  • \$\begingroup\$ Update: fixed using custom defined type conversion function. \$\endgroup\$
    – Prabhpreet
    Feb 18, 2016 at 7:18
Show me why you can't make fract and fract2 subtypes of std_logic_vector:
library IEEE;
package fir_pkg is
    subtype fract is std_logic_vector (bit_width-1 downto 0);
    -- type fract is array(bit_width-1 downto 0) of std_logic;
    -- type fract2 is array((2*bit_width)-1 downto 0) of std_logic;
    subtype fract2 is std_logic_vector(2*bit_width-1 downto 0);
    begin
            seq(i) := std_logic_vector(a_s * b_s);
        end loop;
        return seq;
    end mult;
end fir_pkg;
  • \$\begingroup\$ Fairly new to VHDL. Had never heard about subtype. Thanks! \$\endgroup\$
    – Prabhpreet
    Feb 18, 2016 at 9:08
    \$\begingroup\$ A little better solution: use signed directly instead of std_logic_vector. \$\endgroup\$
    – Prabhpreet
    Feb 18, 2016 at 9:16
  • \$\begingroup\$ See, here's the problem, you're not showing how they are used. You could also simply used range constrained integers. \$\endgroup\$
    – user8352
    Feb 18, 2016 at 9:19
  • \$\begingroup\$ Does integer have support for the multiplication operator? \$\endgroup\$
    – Prabhpreet
    Feb 18, 2016 at 9:21
fract2 is not compatible with signed, and so no multiplier function can be found with the correct return type.
Change the definition of fract and fract2 to this:
subtype fract is signed(bit_width-1 downto 0);
subtype fract2 is signed((2*bit_width)-1 downto 0);
Problem was that the result of product was expected to be signed but was fract2 (custom type defined here) instead.
So, we need to create a function to convert the type. Type conversion is explained here.
The code for the conversion function here:
function conv_fract2(a:signed) return fract2 is
    variable var:fract2;
begin
    assert a'length = bit_width;
        var(i) := a(i);
    end loop;
    return var;
end conv_fract2;
  • \$\begingroup\$ It is always a good idea to self-answer a question. But, you should also show where to call your new convert function. Only this makes your answer helpful for further readers. \$\endgroup\$ Feb 18, 2016 at 14:41
