I have a faulty car (bad central locking engines) and a fuse is blowing every time I open/lock the it. I'm looking to do a quick fix, and just replace it with an automatic fuse. The car runs on ~12V, and the fuse is at 15 ampere.
Are fuses designed to operate on specific voltages, and have their ampere "tolerance" rated for the specific voltage?
As I understand it, a 15A fuse for 12V is designed to blow at 180W (the heat produced in the fuse wiring is what makes it melt, right?).
So, if I use an ordinary 16A/220V fuse in my car, it will blow at 3520W, and should really be rated 293A for a 12V circuit...
If my reasoning is right, that fuses blow at effect and not ampere, what I'm looking for is a 0.8A fuse that is designed for 220V (I=180/230), and it would work as a good replacement...?
