-2
I am working on a project similar to this post. For the circuit diagram on that post, what are the function and working principle of the upper amplifier? I know that the lower amplifier is used to magnify the input signal from the CO2 sensor. Thanks! The design circuit copy from the other post
  • \$\begingroup\$ The answer was in the module in section b. comparator, you guys, you not even read the post of your question ! \$\endgroup\$
    – R Djorane
    Commented Feb 19, 2016 at 11:40
  • \$\begingroup\$ The reason you don't see the functionality is that the schematic is poorly drawn \$\endgroup\$ Commented Feb 19, 2016 at 11:55
The upper opamp is being used as a voltage comparator with its reference voltage being supplied by R1.
The lower opamp has a non-inverting DC gain of 8.5, and when its output voltage is more positive than the voltage on U1-5, U1-7 will go low, turning Q1 OFF and allowing INPUT to float.
However, when U1-6 goes less positive than U1-5, U1-7 will go high, turning Q1 ON, which will pull INPUT down to Q1's Vce(sat), about 300 millivolts above ground, give or take.
In that circuit, the upper OpAmp is taking an input reference voltage on its non-inverting input and the output from the lower opOpAmp on its inverting input.
This forms an OpAmp Comparator, with the Potentiometer setting the comparator's reference/threshold voltage.
  • \$\begingroup\$ A potentiometer is not a varistor. \$\endgroup\$
    – EM Fields
    Commented Feb 19, 2016 at 10:20
  • \$\begingroup\$ @EMFields Thank you, I mis-spoke. Answer corrected. \$\endgroup\$ Commented Feb 19, 2016 at 10:28
