I am reading through "Op Amps for Everyone" by Ron Mancini of Texas Instruments and I can't understand why they have made an assumption:
The specifications for the amplifier are an ac voltage gain of four and a peak-to-peak signal swing of 4 volts.
This is the circuit they give:
IC is selected as 10 mA because the transistor has a current gain (β) of 100 at that point. The collector voltage is arbitrarily set at 8 V; when the collector voltage swings positive 2 V (from 8 V to 10 V) there is still enough voltage dropped across RC to keep the transistor on. Set the collector-emitter voltage at 4 V; when the collector voltage swings negative 2 V (from 8 V to 6 V) the transistor still has 2 V across it, so it stays linear. This sets the emitter voltage (VE) at 4 V.
I can understand this fine. Next step.
This is also fine. However I don't understand the next bit of text:
We want the base voltage to be 4.6 V because the emitter voltage is then 4 V. Assume a voltage drop of 0.4 V across RTH, so Equation 2–35 can be written. The drop across RTH may not be exactly 0.4 V because of beta variations, but a few hundred mV does not matter is this design. Now, calculate the ratio of R1 and R2 using the voltage divider rule (the load current has been accounted for).
Why did they assume a voltage drop of 0.4V across the Thevenin resistor? If it an assumption, then why say it will be close to this value? How did they arrive at the value of 0.4V?
