I salvaged a power supply from an Apple Time Capsule (Delta Electronics ADP-30HF A). This connector was connected to the main board of the time capsule tot supply it with 5.1V.
What is it called?
Delta Electronics ADP-30HF A 5.1 volt connector
  • \$\begingroup\$ It seems to be a SATA power connector \$\endgroup\$ – R Djorane Feb 23 '16 at 12:35
  • \$\begingroup\$ @codo I actually mean the one being measured by the caliper, the other one is indeed a SATA power cable \$\endgroup\$ – Mehdi Nellen Feb 23 '16 at 12:49
It looks like a Molex 90331 series.
They're currently listed as obsolete and I'm not sure what, if any, parts replace them.
    \$\begingroup\$ No. According to your link the series you nominate has a pitch of 3.96mm, this appears to be 2.54mm aka 0.100" as the caliper is showing 6 pins fit in a 680 mill housing. \$\endgroup\$ – Chris Stratton Feb 23 '16 at 16:25
