How do I calculate the cutoff frequency for this design?
equation1
Or simply,
equation2
    \$\begingroup\$ Hello rumman, welcome to EE.SX! Yes the resistances just add. The formulas look good, except the designators are a component off (R2+R3). \$f\$ will be the -3dB point, where V_out is about half of VIN. \$\endgroup\$
    – rdtsc
    Feb 24, 2016 at 23:19
Whenever you have a symmetrical circuit you can cut it in half to make the analysis easier. The equivalent half-circuit will show the same behavior. Please note that I am assuming that R2=R3.
In this case the symmetry might not be apparent, but by replacing the capacitor C1 by two series connected capacitors, each one having twice the value, the circuit becomes symmetrical. And the half circuit is a low-pass with R2 and 2*C that determine the corner frequency. Hence, $$f=\frac 1{2\pi\cdot R_2 \cdot 2C}$$ which is equivalent to your first equation, for R2=R3.
though this is an ancient question, I still want to add somethings. My post is not to directly give the answer corresponded to the question, but analyse a more practical circuit just same as the question's circuit. And it might be more useful for people who searched this kind of questions.
The differential filter circuit provided by the questioner is rather simple, and in practice, a more complex structure is applied.
In this circuit, two differential resistors and three capacitors are used(one differential capacitor, and two common mode capacitors connected to ground)
This filter circuit, in addition, has 20 times broader cut-off frequency in common-mode than differential-mode, this is to prevent common-mode noise from being converted into differential noise due to component tolerances.
The calculation formulas are as follows: Select $$C_{DIF}\ge 10C_{CM1}$$ $$f_{CM}=\frac{1}{2\pi R_{IN1}C_{CM1}}$$ $$f_{DIF}=\frac{1}{2\pi (2R_{IN1}(C_{DIF}+1/2C_{CM1}))}$$
Reference: TI Analog Engineer's Pocket Reference
Why not simply applying the basic rules of circuit analysis?
The current I through the circuit is I=Vsin/(R2+R3+1/jwC1) and the voltage across C1 is
Vc=I*1/jwC1=Vsin/[jwC1(R2+R3+1/jwC1)].
Therefore:
Vc/Vsin=1/[1+jwC1(R2+R3)]
This is the classical first-order lowpass function of the form 1/(1+jw/wc) with the 3dB angular (cut-off) frequency
wc=1/C1(R2+R3).
