I am having strange issue, because when I open my schematic document and try to add component, when I click on Libraries (it doesn't show my project libraries). Libraries. I try to edit in Preferences my paths and default locations but still can not resolve it. My project has two libraries (schematic and pcb), I can see pcb (footprints and 3D models) but can not see components (schematic). PCB libraries (footprints)
Can anyone help me?
EDIT:
Shouldn't Altium anyhow show libraries that are part of my project (in project tree) and are in same folder with project, not linked to the project but directly added?
EDIT:
I tried to set paths to the libraries, to be relative and absolute, neither one worked. Is it possible to be some kind of a bug in Altium? Because Altium 13 works fine with same preference setings.
Click on the Libraries button, and then click the Installed tab. You should have a list of the libraries that are installed. You may have to Install the libraries again, or you may have to click the Activated check box to get them to show up.
  1. First go to view
  2. Then click default layout
  3. Then click default
  4. Then it's gonna show you many bars, then you use or cut it out.
  • \$\begingroup\$ I don't think this answers the OP's question.... \$\endgroup\$
    – DerStrom8
    Mar 7, 2018 at 11:44
