If you place multiple cells of different capacities in parallel, they act as a single cell with the combined capacity of the two. You should never put cells with significantly different capacities in series, since the lowest capacity cell would discharge before the others. This is also why you should (unlike what the picture you posted portrays) connect cells in parallel when they are not in series, as it helps even out the different cell capacities.
By connecting the 1152 mAh and 871 mAh cells in parallel you would get the equivalent of a 2023 mAh cell, while connecting the 1121 mAh and 931 mAh cells in parallel would yield the equivalent of a single 2052 mAh cell. You could then put these two parallel groups in series, to yield a slightly imbalanced 7.4V 2023 mAh pack.
You should also aquire a 2S balance plug extension wire, cut the male plug off and connect the wires to each parallel group of cells in the pack.
That said, I wouldn't try to salvage old, end-of-life cells from some old laptop when 4 brand new 2000 mAh 18650s can be bought online for less than ten bucks. Just don't fall for the "6000 mAh UltraFire" scams, research online which cells are actually good.
