-1
I'm practicing problems for circuits class. Did I write these KCL equations properly? If not, where did I mess up?
Note: on the attached schematic, I'm solving for things in terms of their identifier and not their value, so I marked all the values for R and C as 0. Vp and V0 are node voltages. The voltage controlled current source is gmVp.
  • \$\begingroup\$ It'd be a lot easier to verify if you entered a schematic via the editor and typed out the equations. \$\endgroup\$
    – uint128_t
    Feb 26, 2016 at 3:04
  • \$\begingroup\$ @uint128_t done \$\endgroup\$
    – jonnyd42
    Feb 26, 2016 at 3:25
  • \$\begingroup\$ Even more easier if you specified actual component values instead of 0 ohms and 0 Farads \$\endgroup\$
    – Bart
    Feb 26, 2016 at 14:11
  • \$\begingroup\$ @Bart there are no component values specified. Why the down vote? \$\endgroup\$
    – jonnyd42
    Feb 26, 2016 at 17:43
The nodal equations are correct.
