I am making an "Activity Board" for my toddler. I'm wanting to make an old touch tone phone ring when he pushes a button or picks up the phone. I am hoping someone can help me or point me in the right direction of making the phone ring. To clarify, it is NOT hooked up to a phone line.
  • \$\begingroup\$ Check what the specs say the signal should look like and implement a replica \$\endgroup\$
    – PlasmaHH
    Commented Feb 26, 2016 at 14:47
    \$\begingroup\$ Phone ringing signal (90 volts or so) and toddler plaything are probably not a good mix, honestly. \$\endgroup\$
    – Ecnerwal
    Commented Feb 26, 2016 at 14:49
  • \$\begingroup\$ @Ecnerwal: 30Vish should be sufficient \$\endgroup\$
    – PlasmaHH
    Commented Feb 26, 2016 at 14:51
A telephone ringer is driven by a high AC voltage oscillating around 30 times per second (70V RMS, 30 Hz). This can vary, up or down, slower or faster. It's not particularly picky.
Below is a simple Ring Generator circuit, using a transformer wired "backwards", driven by a dual 555 timer (556 IC). It expects 12V 400mA, but again, can use more or less. I suspect You could even power this from a few (6?) AA batteries in series if you didn't want to use a wall wart.
This ring generator will ring a telephone once every 10 seconds. The interval between rings can be lengthened or shortened by varying the value of the 1 Meg resistor. The 70 volt/ 30 Hz ring voltage is produced from the 120 volt side of a small 12.6 VAC power transformer (Radio Shack 273-1365). Both capacitors connected across the transformer windings are non-polarized / 100 volts. Circuit draws about 300mA from the 12 volt DC power supply during the ringing interval.
A relay or switch at the +12V node should be used to turn the circuit on.
See Wiring up old phone ringer to arduino or http://www.bowdenshobbycircuits.info/page11.htm#ring2.gif or https://www.sparkfun.com/tutorials/50 for some more ideas.
