I'm trying to build the ARM Radio project detailed here. I routed and fabricated a PCB for the anti-alias filter and preamplifier shown on page 2 of the linked PDF, and reproduced here:
Unfortunately there's no mention of what antenna I should use, so I'm trying to use an AM loop antenna taken from a boombox, similar to this one:
Loop antenna
Unfortunately, reception is awful (trying to tune to the local AM broadcast stations). Mostly I get noise mixed with interference from a local FM station broadcasting from about 1 km away. At times I get the feeling I'm getting some reception but frankly I'm not sure. Injecting a weak (~50 mVpp) AM signal from a signal generator directly into the ARM board's ADC (bypassing the anti-alias filter) works fine, producing a loud, clear and correct output, proving that everything from the ADC onwards (software, etc.) is working. Reception is great with a car head unit, parked in the same spot where the SDR was tested, so it's not a signal strength issue. My best theory at the moment is that I'm not using the correct antenna to match the circuit (as shown above, the circuit includes a transformer and an inductor/capacitor network for filtering and impedance matching).
I'd rather build a new antenna than design and build a new circuit to match my loop antenna. Thus: what kind of antenna should I build to work correctly with the circuit above?
    \$\begingroup\$ Based on the data listed in your schematic, your circuit was designed around using a 50ohm, balanced-feed antenna, such as a resonant dipole. Unfortunately, a resonant dipole for AM broadcast radio would be nearly 1000 feet long to resonate at the bottom-end of the AM spectrum. - However, this sounds like an interesting homebrew-type project to me, so I'll see what I can come up with for a way to make an easily-tuned & inexpensive antenna for you to use (then post an answer when I come up with something workable). :-) \$\endgroup\$ Feb 27, 2016 at 4:52
  • \$\begingroup\$ What is your ADC sampling rate and are you aware that the signal out in the schematic is AC and may destroy your ADC - it probably needs to be DC biased. \$\endgroup\$
    Feb 27, 2016 at 12:22
  • \$\begingroup\$ @Andyaka good catch, I missed that bias-loss across C5. Might need to add a voltage divider with series rf chokes to the output of that cap. \$\endgroup\$ Feb 27, 2016 at 12:38
  • \$\begingroup\$ There's a voltage divider on the output, biasing it at half Vcc. See page 3 of the PDF. \$\endgroup\$
    – swineone
    Feb 27, 2016 at 12:40
  • \$\begingroup\$ "Mostly I get noise mixed with interference from a local FM station broadcasting from about 1 km away. " That is not a problem with the antenna. Your system is apparently susceptible to undesired frequencies far out of band, and you need to address that. It could be that your filter stops looking like a filter above some frequency where parasitic properties of components or wiring trumps their intended role, or you could be coupling signal in through power or control leads. \$\endgroup\$ Feb 28, 2016 at 16:18
Ok, doing a little work with the calculators found here and here, I came up with an idea that I think you might like.
Materials:
  • 14ga-18ga "fray wire"
  • 9" section of 4" PVC pipe
  • Power drill with ~1" hole saw & 1/4" bits
  • 3/4" pvc pipe (at least a foot)
  • 3/4" & 4" PVC pipe end-caps
  • 1+ zip tie(s)
  • Magnet wire (about 150')
  • Some BBs, iron powder, etc.
  • 50ohm coax cable (to reach the receiver
  • A 3' or taller frame to hang it all from
If you ground one end of your primary (50ohm) winding on the input transformer, you can then run an unbalanced coax line to a "loaded quarter wave" antenna that can be made resonant with a 50ohm impedance for our band of interest. FYI: AM broadcast band reaches across nearly 2 full octaves of bandwidth (0.5MHz-1.7MHz), so it's not very well possible to receive the whole band resonantly with a 'fixed' antenna.
Construction:
  • Strip the last 1-2" of the coax from the antenna end;
  • Solder a 1' length of the 'fray wire' to the coax center conductor;
  • Drill a 1" hole in one of the 4" pipe caps;
  • Insert the piece of 3/4" pipe through the hole; glue on one 3/4" cap; fill with BBs/iron filings; then slip on the other 3/4" end cap (so the 3/4" pipe filled with metal can slide up & down through the 4" pipe cap, but can't escape).
  • Glue the end caps on the piece of 4" PVC pipe, leaving 6" of 'bare' pipe between the caps;
  • Drill a pair of 1/4" holes near the piece of 3/4" pipe on the 'top' 4" cap (we'll call the 3/4" pipe section the "tuning slug," as that's its function), to attach the rest of the 'fray wire' to for hanging the inductor (whole PVC pipe assembly becomes a 'tunable inductor' once it's done).
  • Solder the free end of the first 1' section of 'fray wire' to a stripped end of your magnet wire, then glue to the side of the bottom 4" PVC end-cap;
  • Wrap the magnet wire around the 'bare' 4" PVC pipe (between the end-caps) for about 150 wraps (or 150' of wire, both are 'close enough'), keeping the wrappings evenly spaced (or evenly overlapped) across the 6" length.
  • Solder another section of fray wire (about 1' long) to the top end of the (now wound) magnet wire & glue to the side of the top 4" cap; then loop the fray wire through the 2 1/4" holes and tie/glue in place for stability.
  • Attach the free end of this top wire to the mounting stand, so that the shield of the connected coax at the bottom can nearly contact the ground.
  • Solder a short "ground lead" of bare wire to the coax jacket (when in use, this wire should be grounded to a ground plane as near to the antenna as possible)
  • Attach a zip-tie "pretty tight" around your tuning slug, so by sliding the zip tie up/down the length of the slug, you can adjust how much of the slug's metal filling is inside the coil (and thus, control the coil's inductance).
OK, that took a bit more explaining "on paper" than I expected in my head, but if you get this far, you should be ready to "fire her up." Start out with the tuning slug mostly outside of the inductor, then tune to a high-frequency band AM signal in your area & adjust the tuning slug for best reception. More slug in the coil = lower frequency tuning for the antenna, so if you can't get the high-frequency station to tune in 'great' at any slug position, try tuning to a lower station; if that works, remove metal filling from the slug as necessary.
  • \$\begingroup\$ OK, I'll try this and report back on how it goes. Thank you very much for taking the time to do this. \$\endgroup\$
    – swineone
    Feb 28, 2016 at 14:44
  • \$\begingroup\$ @swineone Any updates for us? \$\endgroup\$ Mar 4, 2016 at 18:55
  • \$\begingroup\$ The antenna is in the finishing stages of being built, and I'll report back soon. \$\endgroup\$
    – swineone
    Mar 4, 2016 at 18:56
  • \$\begingroup\$ To report back: after reworking the solder in the transformer and one of the DC blocking capacitors, I'm finally getting reception, even with the old loop antenna. However, the reception is noticeably better with your antenna. \$\endgroup\$
    – swineone
    Mar 4, 2016 at 21:13
  • \$\begingroup\$ @swineone awesome; glad your radio & antennae are workin' well for you now :) \$\endgroup\$ Mar 4, 2016 at 22:28
AM broadcast (at around 1 MHz) is easy to amplify, so gain and sensitivity is not your biggest problem. Your observation about noise and another station 1 km away suggest you may have too much signal. Your receiver may be overloaded. Strong signals can drive the front end into nonlinear regions and unwanted signals can mix together to provide all sorts of spurious input.
Before going for the high performance antenna, try a trick or two. Try no antenna, then a short piece of wire. You can also rig up a low-value potentiometer as an attenuator that lets you vary the amount of signal from the antenna that's getting through.
Another possibility is that the amplifier stage is oscillating. That's bad enough but the oscillation will also mix with everything else as described earlier. To test for that I would touch various points in the input circuit and see if it cause big changes. That's not very descriptive but the noise might get a lot worse or it might quit entirely. This is seat-of-the-pants stuff, but I have a lot of experience with this sort of troubleshooting.
Lastly, make sure V2 (the 5V supply) is clean. Taking this from a computer USB port is asking for trouble, at least until the rest of the radio is proven. Use a battery to get a fair test. Once the radio works, you can try the original power source and see if it's clean enough. It might need some RF filtering, which I don't see any of.
  • \$\begingroup\$ Actually, I don't think that's the issue, from checking the output of the circuit with an oscilloscope. The 1 km away station is a broadcast FM one, at 107.9 MHz, so in fact I have no idea how it's showing up in my reception (seeing as there's filtering in the circuit, and the frequency is at least a couple of octaves above the ADC's bandwidth, so aliasing shouldn't account for it). \$\endgroup\$
    – swineone
    Feb 28, 2016 at 14:48
  • \$\begingroup\$ +1 for the mixingmnoise mention...heterodyning could easily be driving the FM station's modulation down into the tuning band (or into aliasing range) of the SDR. - @swineone He mentioned the possibility that some of your components could be being driven non-linear and mixing different incoming signals together, which can "carbon copy" a signal to somewhere far away from its original transmission frequency (looks like about 106MHz away, in this case). Fortunately, using an antenna (system) that's tuned to your desired band does help increase your SNR & weaken such out-of-band interference \$\endgroup\$ Feb 28, 2016 at 20:24
