Is it possible to drive the on-chip oscillator of LPC1114FN28 using the clock output of a FOX924B TCXO? The Datasheet of the uC indicates that a 100 pF cap needs to be put between the oscillator and the XTALIN pin with an additional cap connected to grnd to keep the voltage limited to 1.8V. Considering that output load as per the FOX924B datasheet is limited to 25pF, the 100 pF cap recommended by NXP seems too much for the TCXO. Am I right?
Also, why can't I simply use a resistor based voltage divider to bring the TCXO output to 1.8V?
