I have installed ModelSim 10.4 X64, when I want to open a vhd file in editor an error shown in "Transcript" window as : " could not find interpreter "ScintillaTk" "
I searched about that and I found out that this problem occurs when ModelSim installation path have a space character !!
I have installed it in "Program Files" Folder, Now how can I solve this problem without installing it again ?
I have changed the "Path" environment variable`s value form -path- to -"path"- but the problem not solved ...
    \$\begingroup\$ Create a directory junction from somewhere like C:\modelsim\ to C:\Program Files\<modelsim folder>\ and set the path, environment variables, and shortcuts for modelsim to point to that location? \$\endgroup\$ – Tom Carpenter Feb 27 '16 at 19:35
    \$\begingroup\$ Thank you @TomCarpenter, I think that is better to be as an answer with more explain and images, If you don't time for that, I'm glad to do that. \$\endgroup\$ – QMaster Mar 3 '17 at 19:02
  • \$\begingroup\$ What do you mean "directory junction" \$\endgroup\$ – Jonathan May 6 '17 at 2:19
Thanks to Tom Carpenter for his solution I write the answer for others who may have the same problem.
Create a directory junction from somewhere like C:\modelsim\ to C:\Program Files\ (modelsim folder)\ and set the path, environment variables, and shortcuts for modelsim to point to that location? – Tom Carpenter Feb 27 '16 at 19:35
this can be solved by creating directory junction link to modelsim installation folder. you can create link with mklink command in cmd.
mklink /J "Link" "Destination"
e.g. mklink /J "C:\modelsim" "D:\program file\modelsim"
after creating the link the path in environment variables should be updated with the link address.
The shourcut target should get updated too.
e.g. C:\modelsim\win32pe_edu\modelsim.ex
I had the same bug. It's more simple than doing that with mklink.
Just move the installation folder in C:\ -> that will be enough. Good luck guys!
