-1
I am using libmodbus to connect to the a SunnyBoy 2.5 inverter. I make the connection as follows:
#include <modbus/modbus.h>
#include <stdio.h>
#include <errno.h>
int main()
    modbus_t *mb;
    uint16_t tab_reg[32];
    int rc;
    int socket;
    mb = modbus_new_tcp("192.168.100.1", 502);
    if (mb == NULL)
        fprintf(stderr, "Unable to allocate libmodbus context\n.");
        return -1;
    if (modbus_connect(mb) == -1)
        fprintf(stderr, "Connection failed: %s\n",
                modbus_strerror(errno));
        modbus_free(mb);
        return -1;
    else
        socket = modbus_tcp_listen(mb, 1);
        if (socket == -1)
            fprintf(stderr, "Socket problem: %s\n", modbus_strerror(errno));
        modbus_tcp_accept(mb, &socket);
        printf("Connection successful.\n");
When I attempt to listen on the socket (modbus_tcp_listen), it gives me a "permission denied" error. How does one gain permission to the SunnyBoy to talk Modbus to it / how do you implement that in the code?
    \$\begingroup\$ Do you think that lot of people on this forum know about libmodbus library and your platform (that you didn't describe) to help you? Further, a modbus is a protocol of numbers, so where did you get the "permisson denied" as the modbus hasn't this feature. \$\endgroup\$ Commented Feb 29, 2016 at 9:26
  • \$\begingroup\$ What does the manual for the device say? \$\endgroup\$ Commented Feb 29, 2016 at 19:31
You're getting this message because modbus uses port 502. In Unix port numbers below 1024 require root access, so try using
sudo bash
To get a root shell and give it a try. You'd also be better off using a scripting language that has a modbus library. This will let you produce fast prototypes with your Sunny Boy.
