I new to hspice, i searched on the hspice docs, but still cannot clear about this option. What does this option actually effect on simulation.
.param dummy=1
.dc dummy 1 1 1
Please help me on this! Thanks very much!
  • \$\begingroup\$ I am confused, what's the problem? \$\endgroup\$ – Spoon Mar 1 '16 at 12:35
Basically this will run the simulation with dummy = 1.
The .dc command defaults to a linear scale, but you've put 1 as the starting point, ending point, and increment.
If you want to run the simulation with dummy = 1, then 2, then 3 for example use .dc dummy 1 3 1 (i.e. 1 to 3 incremented by 1)
see http://www.ecircuitcenter.com/SPICEsummary.htm
| improve this answer | |
