I'm having an issue with a Mosfet driver that I put together. It is a MSP430FR4133 taking in 3 square wave signals and outputting them at a higher frequency. The new signal is put through 3 separate Mosfet drivers to drive LEDs. The problem I'm having is, when I dim the LEDs the Mosfets output the wrong signal at the 2% - 19% Duty cycle Range. 1% works fine and 20 - 100% work fine. I'm sure that I'm just missing some supporting components but I'm really unsure what I'm missing.
Sorry if the schematic is rough, this is my first time using that software. Here is the signal after the MCU
Here is my issue, after the MOSFET
Edit - I added a Pull up resistor on the drain and it made the waveform more stable. It now inverts the output of the MOSFET in between 2% and 19% Duty Cycle. I updated the issue picture with the new waveform. It is literally inverted from what its suppose to be.
Edit 2 - A symptom of the problem has been found. The Drain voltage is linear when its functioning properly. It is nearly the full 12 volts when we are at a 1% duty cycle and at 20% duty cycle we are at 10 volts. Going up from there the voltage drops properly. In the Problem area of 2% to 19 % duty cycle the voltage starts at 3.3 volts at 19% then around 16 % raises to 5.6 volts then drops down to 1 volt at 2 %. I originally was using a Launch-Pad for the processing of this application but I have now mounted the processor onto the PCB and I'm getting the same issue. The ground that's connected to the MOSFET is the same ground that is runs through the entire PCB. I'm not sure if a ground issue would cause this problem considering the problem is so repeatable. Another Observation is that the problem is eliminated when I drop my frequency down to 600 hz which is the frequency of the input signal coming into my MCU. The higher the frequency the greater the issue.
Edit 3 - After doing some more research I believe that this issue is called Capacitive False Turn-on. Does anyone have advice as to how to fix this? The traces on my board are really thin because its a prototype board, is there something that I can add in order to fix this issue without getting a new prototype board? I have tried lowering the resistance of the Rg to 10 Ohms and it made the issue happen at 10% duty cycle instead of 20% and 1% is now messed up. It shrunk the problem area but hasnt solved it. When I raise the resistance, the issue gets worse.
  • \$\begingroup\$ Looks as if the whole scope is wavering all over the place... ;o) \$\endgroup\$
    – jippie
    Commented Mar 4, 2016 at 21:28
  • \$\begingroup\$ driver datasheet mouser.com/ds/2/205/IXD_604-13868.pdf \$\endgroup\$
    – jippie
    Commented Mar 4, 2016 at 21:32
    \$\begingroup\$ I don't see the decoupling caps in your circuit diagram. \$\endgroup\$
    – jippie
    Commented Mar 4, 2016 at 21:35
    \$\begingroup\$ Why do you have a resistor on the gate of the mosfet? \$\endgroup\$
    – user102481
    Commented Mar 4, 2016 at 21:39
  • \$\begingroup\$ The LED should have a resister .You have used a big mosfet with lots of capacitance which adds to the LED capacitance .If you pull up the drain experimentaly with say 1K ohm you should see some waveform improvement which will confirm the capacitance issue. \$\endgroup\$
    – Autistic
    Commented Mar 4, 2016 at 21:50
After much testing I finally found the solution. This Article States that :
For high current MOSFETs the Gate Channel Capacitance can be very high and a rapidly changing drain voltage can produce milliamps of transient Gate current. This could be enough to overdrive and even damage delicate CMOS driver chips. Having a series resistor is a compromise between speed and protection, with values of 100R to 10K being typical. Even without inductive loads there is dynamic gate current. Also, MOSFETs are extremely susceptible to damage caused by electrostatic discharge and can be damaged irreversibly by a single instance of Gate breakdown. For this reason it is a very good idea to use gate series resistors of 1K to 10K. This is especially important if the Gate signal comes from another circuit board.
After Reading this I changed my Series Gate Resistor to 1k and the problem vanished entirely. It would appear that when your a higher frequency with a capacitive load you need a higher Series Gate Resistor.
  • \$\begingroup\$ Are you switching at 10kHz? because that is not a high frequency \$\endgroup\$
    – hassan789
    Commented Mar 9, 2016 at 18:47
  • \$\begingroup\$ Yea, I'm at 10khz. If the frequency wasn't the issue then it must have been the capacitive load. \$\endgroup\$ Commented Mar 9, 2016 at 20:08
